Results 1 to 6 of 6
    Jul 2002
    SE Texas
    Jackson Crew 44 Drive Assembly Motor Removal
    I'm going to be changing the motor for the drive assembly. The motor isn't shown in the diagram, but I believe you can tell where it's mounted. The motor shaft is connected to the gear drive assembly (#3). I'm sure I'll need to remove the gear drive assembly in order to remove the motor, but I have no idea how the motor is coupled to the assembly. I'm sure I can figure it out once I remove the components, but I was hoping someone who has removed the motor can provide some guidance. Thanks.
    With your chrome heart shining in the sun, long may you run.
    Jan 2016
    The triangle in the Keystone
    Looks like the gear drive assy has a key way shaft insert. I’m thinking the motor shaft slides right in and they bolt together? Not sure, never worked on one myself.
    Waterloo N.Y.
    Best guess is a lovejoy coupler like Hobart.
    There's TREACHERY AFOOT!!!
    Oct 2008
    I've never worked on one either.
    Looks like you'd just need to remove four bolts and slide the motor out of the gear box (#3 in your diagram).
    Here's some pictures of the gear box.
    "You never know what others don't know." -
    If I can't laugh at myself...then I'll laugh at YOU! -
    Oct 2008
    Maybe the two threaded holes at 3 and 9 o'clock would be where you'd take two of the four previously removed bolts, insert them in the opposite direction, then use those bolts to press out the motor.
  6. Likes The Turtleman liked this post
  7. #6
    Jul 2002
    SE Texas
    Quote Originally Posted by ECtofix View Post
    I think you're right. I appreciate it!
