Results 1 to 7 of 7
    Windsor area Ontario Canada
    Lennox G24M3-75A-1
    Lennox mid efficiency g24m3-75a-1
    This furnace has one LED light not two and i cannot find the flash codes anywhere. Does anyone have this?
    I keep getting six flash code and cant figure out whats going on. I reset it and it works for a couple weeks then they call back for no heat. I cleaned the flame sensor and changed ventor and pressure switch because they were falling apart. I cannot find anything else wrong with this furnace.
    Jun 2017
    Phoenix, AZ (Previous: Texas, Oklahoma, Oregon)
    Quote Originally Posted by markmast View Post
    Explain what happens during call for heat
    Sent from my LM-G710VM using Tapatalk
    Quote Originally Posted by FreeThrowGuy View Post
    Thats the thing it works fine every time i go there. But once when i arrived it flashed 6 times. Thats the only time i saw that fault and theres nothing that says flash codes. I pulled hose of pressure switch it was 3 flash, limit was 2 flash, failed ignitikn was 4 flash. Everything checks out fine. Gas pressure good, voltages amd amp draws are good. Checked all neutrals and ground
    You must have the HSI version of this unit.
    Check your email and look at the last page of the installation manual I sent.
    Quote Originally Posted by rundawg View Post
    Thank you for the manual, i could jot find that one amywhere! 6 flashes says HSI failure which is strange because it looks good and ohms out ok. I was thinking it may be the board because its original and the problem occurs about once every 2 weeks. Appreciate the email.
    Michigan's Upper Peninsula
    Still possible for the board. Seen some intermittent failures where it goes for days or weeks.
