Results 1 to 13 of 26
    Nj Pa De
    Low Pressure Recovery
    I am just looking for options on an issue I run into occasionally.
    Low pressure Chillers with leaks , prior to repair will no doubt be full of non condensables. When you recover the charge for repairs, liquid recovery via push pull is easy. But then there’s the vapor with non condensables.
    Now if it is were r11 , it was easy in the past. But r123 has presented safety issues. Usually we bring in a water cooled purge to assist and recover into tanks. However the water cooled purge isn’t always available.
    I’ve tried recovering with just using recovery machine which has a water cooled condenser. However the low pressure recovery tanks relief valve is set at 15 psi. The tanks over pressurize quick. But when there is 1 or 2 hundred pounds of vapor left , what are the options? Do you charge additional to dispose of and add fresh ? Charge extra to distill/ clean ? And what is the most cost effective method in this situation.
    I’m just putting this out there for professional opinion. Locally I hear almost something different from each tech I talk to. Thanks for look8ng.
    cant make this crap up
    in a tree looking in your window
    This will be good, I know what most people do.
    If you dont stand behind our troops, please feel free...........to stand in front of them.
    Jun 2010
    U.A. (upper Alabama)
    Quote Originally Posted by chillrdude View Post
    I don’t do that!
    ottawa canada
    R123 safety issues ?
    Such as ?
    Get an air cooled portable purge...they are nicer and easier to use. You can also use a large empty tank for the vapor recovery, install a 10 psig pressure relief and let the tank and relief valve act as a purge. Not as effective as a mechanical purge but it works, especially if you have lots of air or leaks and may not get it all out. You have to expect that you won’t get it all out with a machine that has large leaks, anyway.
    Technically speaking, they are all heat pumps.
    Quote Originally Posted by cperk View Post
    I don’t do that!
    me neither, I cant even spell deminnus
    Southold, NY
    Oregon
    You have to use a purge on your tanks, it's the only way to do it. I would never hook a hose up to the tank with the valve slightly cracked and vented through the rupture disc line.
    Federal Reserve, stealing your kids futures since 1913
    UA290
    Quote Originally Posted by acjourneyman View Post
    I would also never set the relief valve on the tank to 4lbs.
    Nj Pa De
    Just as I suspected.... Feel better knowing we’re all on the same page , well at least same chapter...
    I always wondered why the relief valve outlets had hose fittings , lol.
    Thanks for feedback
    ottawa canada
    Quote Originally Posted by jerseydevil View Post
    Thanks for feedback
    I would still like to know what the R123 safety issues are
    Southold, NY
    Quote Originally Posted by Healey Nut View Post
    Causes Cancer in California!
    ottawa canada
    Guess Im ok then seeing as Im in the great white north .
    PS its -22C here today
