Results 1 to 4 of 4
    Mar 2013
    Southern Ontario
    Distech Jace to JCI FX Question
    Question regarding upgrading a Jace..
    I currently have a site using a Distech Jace, I've been asked to look into upgrading the controller. If I would upgrade I would upgrade to a JCI FX80. Being that the site uses Distech controllers and Distech EC-gfx, if I were to upgrade to a FX80 would I be able to install EC-gfx on a local PC and connect/program through there?
    Previously I would launch the wizard through the Distech Workbench.
    Hampton Roads, Virginia
    To run them in any workbench other than a Distech one you will need a Distech support license from your friendly Distech distributor. Not sure about support license if using FX with Distech WB.
    Being a controls technician often reminds me of this story:
    https://www.youtube.com/watch?v=Wdg50zgK7fA
    Especially when the customer complains about the bill.
    Controls is a lifestyle not a job
    Jun 2012
    Quote Originally Posted by klrogers View Post
    I believe you have it backwards. GFx is not tied to workbench. The JACE must be either Distech brand or have a Distech support pack license.
    Quote Originally Posted by JSLLC4Life View Post
    Yes you are correct, thinking about it I have used a Vykon WB on a Johnson FX80 with Distech support licence to add/program Distech controllers. However to use your engineering laptop as the server and connect to a Distech controller for programming purposes requires the Laptops N4 WB to have a Distech support license.
