+ Reply to Thread
Thread: Help with fireplace remote
    I have a gas fireplace with an Acumen remote that is about 15 years old. The remote operates inconsistently, does not come on/off properly with temp settings, seems to work sometimes, not others.
    I have tried trouble shooting, changing batteries, etc. to no avail. Should I replace this and, if so, what do I shop for?
    Sep 2016
    PL In New York
    In some cases, the remote will have a receiver module that simply ties in series to the toggle on/off switch which would then be left in the ON position at all times. As the remote signals, the receiver simply acts as a switch. A click being heard would indicate the part is working. This is a very basic instance simply used to described how a system could work and should not be taken literal. I've had to replace a gas valve for the same reason you are describing. Depending on the fireplace it could be alot of things.
    Jan 2019
    Ct
    Are there batteries in the receiver that need replacing?
    Sep 2016
    PL In New York
    There may be but in some cases it plugs into an wall outlet or connecting where power is supplied to the unit. Every system is different and in most cases if the batteries are good in the remote, and there is power at the receiver further diagnosis would be taken by a qualified professional. Improper maintenance or repairs could cause fire, injury, property damage or loss of life.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
