Results 1 to 10 of 10
    Apr 2008
    South New Jersey
    First time Iíve seen it done. Wow!
    Walked up to this today at a closed restaurant just following up on a recommendation to replace a CFM. Opened the electrical compartment and seen this.
    Jan 2014
    New England
    Are you referring to the missing compressor bolt? You would think if anything the compressor bolt behind the compressor would be missing as it's harder to get to, certainly there could be just two bolts holding down that compressor, or the bare white wire doesn't look like it's hooked to anything thou, just goes to ground. The capacitor and bare wire at first is a wake up call to keep the Tech. on their toes while removing the access panel and troubleshooting.
    Can only guess what the points on those Contactors look like, end screw is rusting on left load side and discoloration on surrounding area of that screw, the other the screw is missing on the load side of the other. Typically you would use the two outer connectors instead of next to each other, guessing the points where flat out arced/pitted out bad.
    Would be curious to see the compressor terminal hookup condition.
    Feb 2018
    Bay Area, Ca
    No that capacitor is free air. Keeps it cooler. The tape is just a safety precaution. Lol.
    Sent from my SM-G955U using Tapatalk
    Dec 2012
    columbus, OH
    A real tech would have cradled that capacitor in the service manual...
  5. Likes UrAverageAguy, lions_lair liked this post
  6. #5
    Jan 2014
    New England
    Or as I do, leave the cap. in the box that it came in
    Meant to get back to that unit to make proper repairs, but was called off job, fell through the cracks....
  7. #6
    Apr 2008
    South New Jersey
    At first I looked at it and got curious wondering what would result from a run cap connected to a 3 phase compressor because this units data tag list compressors as 3 phase but that curiosity quickly faded after the no it just canít be thought hit me, and I wiped the compressor tag off to find itís a single phase replacement compressor. No suprise there either after seeing the disgraceful condenser motor change outs done sometime in the past. Capacitors installed taped to wires in the condensing section. Motors and blades used hardly a match to what should be there. Laziness and zero pride in workmanship combined with incompetence never ceases to amaze.
  8. #7
    Jan 2012
    Broomall, PA
    You guys don't realize, the tape is applied with a drip leg. It's very safe this way.
    At least he didn't try to screw a bracket into the compressor.
    Uh...Google it yourself!
  9. Likes Lahrs liked this post
  10. #8
    Sep 2018
    Nah a real tech wouldíve at least left it in the box lmao
  11. #9
    what is with the disconnected white ground wire
  12. #10
    Quote Originally Posted by drpsr99 View Post
    The most clever ghetto rig ive seen with fans ..... was a walkin cooler ... the condenser on the roof had the whole top grill with fan from a residential OD unit grafted into it
