Results 1 to 10 of 10
    Jan 2019
    Freezer or refrigerator? Home owner question
    My goal is to maintain food temperature at zero degree C (32 deg F) plus minus a few degrees of fluctuation. A plan is to buy a freezer and a thermostat controller from Amazon to switch on/off the freezer. The other plan is to get a refrigerator and keep the refrigerator section at the lowest setting. I prefer the freezer approach because of better temperature control. But I wonder if I will run the freezer out of the designed temperature range and ruin it prematurely. Thank you.
    Southold, NY
    yes you should be concerned. Operating at 32f is at its highest operating pressures if not above.
    Why 32f?
    Mar 2015
    Medford, N.Y.
    What product are you using? How long will the product be kept at your desired temp?
    Southold, NY
    Terry
    Hows the Foot?
    Jan 2019
    Thank you for the explanation that 32 F would set refrigerant pressure above the highest design pressure. I have never thought about this. I was thinking about a chest freezer from Home Depot, Best Buy or Sears. Based on your recommendation, I will buy a refrigerator and set temperature at the lowest setting. Thank you.
    By the way, I don't understand the question, "how is the foot"? I don't know much about refrigeration.
    Jun 2014
    Dover, DE
    If you buy a refrigerator, and set it to 32*, what will you do about defrost?
    I havent failed. Ive just found 10,000 ways that wont work. - Thomas Edison
    Its not whether you get knocked down, its whether you get up. - Vince Lombardi
    "In this house we obey the laws of thermodynamics" - Homer Simpson
    Local 486
    Apr 2003
    Maple Grove, MN
    Quote Originally Posted by rider77 View Post
    As long as he's talking about an average fridge/freezer combo then I think he'll be OK, since defrost will still happen just like it's supposed to in the freezer section.
    Hey Parker, you like yourself some cold beer, don't 'cha? Is that what this is about?
    If at First You Don't Succeed, Skydiving Is Not for You.
    Jan 2019
    Quote Originally Posted by ammoniadog View Post
    Yes, that's my revised plan to buy a top-freezer buttom-refrigerator and keep the refrigerator at low temperature setting. Yes, similar to kegerator.
    I haven't thought about defrosting. What if I turn off auto-defrosting and do manual defrotsing?
    Mar 2015
    Medford, N.Y.
    Terry
    How’s the Foot?
    Foots fine ,3 weeks to go.
    Southold, NY
    Quote Originally Posted by TechmanTerry View Post
