    Athens, Ohio
    Sensi thermostat recall
    I learned of this in an e-mail today. I don't use Sensi but they are sold by the distributor we use.
    From the link- "Incidents/Injuries:The firm has received eight reports of burn damage to the thermostat, involving minor property damage. No injuries have been reported."
    https://www.cpsc.gov/Recalls/2019/Wh...to-Fire-Hazard
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
    Mar 2016
    It's not a line voltage stat, homeowners need to quit hooking them up to a 110vac circuit....Especially without a ground :tard:
    Sent from my SM-G892A using Tapatalk
    Oct 2013
    Rochester, NY
    So are they saying we should replace all of the ones that were installed? Even if not near line voltage?
    Athens, Ohio
    Quote Originally Posted by Hvacrookie86 View Post
    The page is not specific as to the cause or condition.
    In any case, low voltage wires should never be routed with line voltage wires unless the insulation rating is the same. The insulation on #18 gauge thermostat wire does not meet this requirement.
