+ Reply to Thread
Results 21 to 38 of 38
Thread: Why Hoshi....whyd ya do it
  1. #21
    Virginia
    Its not gonna be easy to torch inside the Head unit if I cut the threaded ends off
  2. #22
    Southold, NY
    Quote Originally Posted by Snapperhead View Post
    You can do it.
    S B 8
  3. Likes shellkamp liked this post.
  4. #23
    Virginia
    This is taking F o r e v e r to suck out.... and I have the jug sitting in ice
  5. #24
    Virginia
    Im still waiting for the recovery machine to suck it out .. and it's given me some time to think , and I'm thinking those rubber O-rings do play a role in Sealing because there is no Teflon rings in there and I doubt they would rely on a Brass to Brass seal ....ya think ?
    There are new Orings in the unit ..
    Soon as you remove the plastic dust covers you can see them.
  6. #25
    May 2014
    Bay Area California
    Haven't you heard? All of the refrigerants in use today are eco-friendly. No need for recovery.
    I read the units label and it said 22 lbs of 404 , and my reclaim jug is about full of 404 , and my other jug I let a buddy use which is full of 22 , so im like …. crap
    I do a triple evac with nitro to remove non condensables.
  7. #26
    May 2014
    Bay Area California
    Oooops, just noticed this is an open forum.
  8. #27
    Southold, NY
    The O-Ring is the seal. A little oil MUST be applied to the O-Ring when tightening.
    Another reason to cut them out and replace!
  9. #28
    Jul 2000
    Guayaquil, EC
    I believe Hoshi's pre-charged connectors are Aeroquip Series 5780, which use the O-rings for sealing during connecting, but the final seal is metal to metal.
    Name:  Aeroquip-5700 Couplings.png
  10. #29
    Virginia
    Well aint that sumpthin
  11. #30
    Jan 2010
    Well....is it done ?
  12. #31
    Virginia
    I think my pump finally quit. I ran some errands and after 6 hours its only recovered 11 lbs . Im screwed. WTH can I do now. Nothing until wed.
  13. #32
    Virginia
    Finally some luck , my buddy was working across the street ! Borrowed his unit and got her emptied.
    Ok so im a big dummy. I shoved a ice pick into the metal cover and saw the piercing blades are behind it !!!!!
    SOB
    So the lineset doesnt do the piercing... It merely shoves against that metal cover and the blades poke thru .. and the blades end up going inside the lineset !
    Whoooda thunk
    Got it vacuumed , charged , and it just dropped a load of ice
    Soaped the fittings real good and no bubbles
  14. #33
    Jan 2010
    SOB
    Whoooda thunk
  15. #34
    Aug 2001
    I someone is determined the fittings are available from Hoshi.
  16. #35
    Jan 2019
    Quote Originally Posted by icemeister View Post
    If the original precharged connectors worked OK, there's no reason they won't work again even if the seal didn't appear to get fully opened. They can be reused but only thing that matters is that they don't leak, but that's a crapshoot. I used to carry replacement O-rings but rarely ever used them.
    Since they're really only there to assist in the initial piping job as shellkamp mentioned, they're of no functional value except as a coupling anyway, so just replace them with a sweat coupling.
    I remember my father back in the 1960's when precharged linesets first showed up on split A/C units saying "Those quick-connectors are going to allow tin-knockers and plumbers to do air-conditioning work Lucky Patcher 9Apps VidMate ." Now everybody uses them simply to save time and money...and nobody cares that the piping job looks like a rats nest
    very good when you remember your father since 1960
  17. #36
    Jun 2006
    Been paid more than one warranty call for an areoquip leaking
  18. #37
    Mar 2015
    Hamersville, Ohio
    Quote Originally Posted by shellkamp View Post
    It's too bad they don't sell recovery jugs anywhere... Or swap full ones out with empty ones.... Hmm....
    Think I'm gonna create an establishment that does just that.
    Might sell parts for stuff there, too.
    Sent from my Moto Z (2) using Tapatalk
    Hos 4:6 My people are destroyed for lack of knowledge. Because you have rejected knowledge, I will also reject you, that you may be no priest to me. Because you have forgotten your God’s law, I will also forget your children.
    "You've got to Stand for Something or You'll fall for anything" (A. Tippin)
    Mat_15:24 But he answered, “I wasn’t sent to anyone but the lost sheep of the house of Israel.”
  19. #38
    Feb 2007
    milford ct
    you can obtain new ends from hoshi.
    If a Ram is a Sheep, And an Ass is a Donkey, Why is a Ram in the Ass a Goose?
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
