Results 1 to 9 of 9
Thread: press systems
    Dec 2018
    press systems
    What are the pros and cons of the Zoomlock fittings and tools? Is there a better alternative?
    Sep 2016
    I would say one con could be any knuckle head can get their hands on one and not use it correctly and cause leaks. But that already happens with brazing anyway.
    The upfront cost of one these machines is pretty expensive they are around 3k if I remember correct also the fittings are pretty expensive as well. But I would argue that you would make your money back over some time using it.
    pros:
    They are much faster.
    Looks cleaner.
    no need to flow nitrogen.
    No need for fire spotter if you are in a confined space.
    I am sure there are more I just rambled off a few.
    Dover, Pa.
    Usually used for installs to save time on larger jobs.
    Have been reliable so far.
    Service guys have started using them if their companies already have them.
    Fitting costs are outrageous.
    I can install faster, cheaper and more reliably using regular old fashioned fittings, staybrite 8 and braze rods (installation specific uses)
    Good mechanics are getting harder to find.....have you encouraged or discouraged a young mechanic today?
    Southold, NY
    Quote Originally Posted by bradysmill View Post
    What about the extra cost for a fire watch and or fire guard?
    Jul 2019
    NY
    Awesome from an installer's POV but not for the service end. Just wait for refrigerant rated shark-bite fittings!
    Southold, NY
    Quote Originally Posted by pough913 View Post
    Same as Brazing....When done properly No Issues!
    Southold, NY
    Mar 2010
    Arnold, Mo
    He's a spammer waking up old threads.
    May 2020
    The clean look of press tools is a big seller when it comes to impressing your clients as well. Worth the investment to make the job easier in my book - Good luck!
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
