Results 1 to 13 of 16
Thread: Filthy Rat
    Jan 2016
    The triangle in the Keystone
    Filthy Rat
    I was working on a Rational at a KFC recently. The call was for a service 34.1, no big deal. When I got there and looked at the service history I found over 1200 service 34s and over 5000 service 37s!!! The unit was the dirtiest combi Ive ever seen. Utterly filthy inside and out. The P1 pressure port behind the fan was clogged (hence the 37s) so bad I had to drill out the carbon buildup. When I tested it in steam mode I noticed a ton of steam billowing out from the underside of the unit and nothing coming out of the drain vent stack. Weird? I look in the stack and find its packed tight with carbon buildup. From top to bottom its clogged and so is the rubber boot on the bottom and the drain box 70% full of this carbon.
    Anybody remember when KFC started using the Blodgett Excel ovens? Remember what the chicken byproducts would do to that oven? Well, even a Rational with its sophisticated Care Control system cant even keep up with the cleaning demands that it requires.
    Aug 2010
    Living rent free
    Well, no.. But I did eat at kfc yesterday. First time in a couple of years.
    Sent from my LG-K540 using Tapatalk
    "If you cant describe what you are doing as a process, you dont know what you are doing." ~ W. Edwards Deming
    All those who wander..are not lost.
    Do NOT..mistake my kindness for weakness.
    The early bird may get the worm..but the second mouse gets the cheese.
    Mar 2015
    Hamersville, Ohio
    Quote Originally Posted by VanMan812 View Post
    I was working on a Rational at a KFC recently. The call was for a service 34.1, no big deal. When I got there and looked at the service history I found over 1200 service 34’s and over 5000 service 37’s!!! The unit was the dirtiest combi I’ve ever seen. Utterly filthy inside and out. The P1 pressure port behind the fan was clogged (hence the 37’s) so bad I had to drill out the carbon buildup. When I tested it in steam mode I noticed a ton of steam billowing out from the underside of the unit and nothing coming out of the drain vent stack. Weird? I look in the stack and find it’s packed tight with carbon buildup. From top to bottom it’s clogged and so is the rubber boot on the bottom and the drain box 70% full of this carbon.
    Anybody remember when KFC started using the Blodgett Excel ovens? Remember what the chicken byproducts would do to that oven? Well, even a Rational with its sophisticated Care Control system can’t even keep up with the cleaning demands that it requires.
    Dang!!!!!!
    Hos 4:6 My people are destroyed for lack of knowledge. Because you have rejected knowledge, I will also reject you, that you may be no priest to me. Because you have forgotten your Gods law, I will also forget your children.
    "You've got to Stand for Something or You'll fall for anything" (A. Tippin)
    Mat_15:24 But he answered, I wasnt sent to anyone but the lost sheep of the house of Israel.
    Jun 2014
    Dover, DE
    Made a lot of money at KFC due to things like that, although I never did hot side work.
    Disturbed a nest of around 250 roaches one time in a roll away under counter cooler just behind the cashier. About 20 people in line saw it and just left.
    I havent failed. Ive just found 10,000 ways that wont work. - Thomas Edison
    Its not whether you get knocked down, its whether you get up. - Vince Lombardi
    Jan 2016
    Quote Originally Posted by rider77 View Post
  6. Likes lions_lair liked this post.
  7. #6
    Jun 2013
    Yes, indeed. What a mess. And that liquid cleaning solution would burn holes in your uniform.
    And when I heard they were going to Rationals instead of the Excels, I decided it was time to retire.
  8. #7
    Jan 2016
    Quote Originally Posted by BadBozo2315 View Post
    That cleaning solution was something else. Dangerous is how I would best describe it.
  9. #8
    Jun 2014
    Dover, DE
    The manager just started pouring buckets of water on them trying to wash them out of the customers view. But all it did was create a roach water park.
  10. #9
    kansas
    KFC and several other chicken places is definitely on the list for a refer guys not to eat at right there with the Asian places
  11. #10
    Jul 2018
    Wisconsin
    Like when you see chicken feathers in the exhaust fans of some Chinese restaurants you know it's fresh
  12. #11
    Oct 2019
    Wow thats narly, I remember fixing the Blodgett ovens when they released with the grilled chickens here in Hawaii, never knew they started using rationals.
  13. #12
    Oct 2008
    I don't know how I missed this nearly year old post. What a friggin' MESS!
    VanMan, I have nothing to compare. However, we did have a particular cook set a SCC101 oven on fire...TWICE!
    This cook had his own technique for roasting cuts of red potatoes, using HIGH heat and drizzled heavily in oil. For whatever reason, he'd put a pan underneath the perforated pan of potatoes to catch the drippings. Batch after batch - every morning.
    Blower setting was at HIGH, so the torrent airflow sucked up the oily drippings from that catch pan and blew it onto the oven's walls around the heat exchanger. It built up. THICK!
    Thick enough to bridge the 1" gap behind the heat exchanger and the oven's side wall. At that point, with a call for HEAT...we had IGNITION!
    Potatoes got SMOKED!
    HE was eventually FIRED for being a knuckehead. On both occasions, I got to sit inside the oven for many hours with razor blades and a putty knife to scrape away the mess.
    Quote Originally Posted by MauiTech View Post
    I didn't work in KFCs much, but I remember being flippant with them once by asking what kind of GRILL they use to GRILL their GRILLED chicken.
    I knew better. I was confident that the grilled chicken, being a product of the YUM! conglomerate, was done in a factory and reheated at their restaurants.
    Taco Bell is their greatest example of the YUM! practices. Nothing in a Taco Bell is cooked in the restaurant. Just products in bags being RETHERMALIZED.
    "You never know what others don't know." -
    If I can't laugh at myself...then I'll laugh at YOU! -
  14. #13
    Jun 2013
    > that the grilled chicken, ..., was done in a factory and reheated at their restaurants.
    Don't I wish! No, the chicken was fresh (ish?) and raw, grilled to perfection on specially stamped pans.
    Actually pretty common at the places I had worked at, greasy foods, high temps, electric oven elements. Crap would build up in the front left corner and light off, trip the cabinet high limit.
    Fun times!
