Results 14 to 24 of 24
    Mar 2015
    Hamersville, Ohio
    Quote Originally Posted by Lahrs View Post
    So, we were called there due to MUA having a high discharge air temp issue. This is what one of our guys found, along with some maxitrol issues.
    Onsite maintenance hadn't heard anything out of the ordinary. :0
    I'm kind of proud of my temporary repair. Tempted to change out the other bearing to a pillar and calling it fixed.
    Outstanding Lahrs!
    How close to the brace is the belt?
    Hos 4:6 My people are destroyed for lack of knowledge. Because you have rejected knowledge, I will also reject you, that you may be no priest to me. Because you have forgotten your Gods law, I will also forget your children.
    "You've got to Stand for Something or You'll fall for anything" (A. Tippin)
    We are on a "Man-made Highway to Hell", Our so called "Leaders", Political & Religious, are encouraging The Mushroom like Sheeple to go faster.
    (AC-DC Lyrics)
    May 2014
    Bay Area California
    Yup.
    When I first saw those, I had a helluva time taking them off. I quickly learned to inspect that 'tapping' hole to see which way they were put on. And they where always backwards. Then I saw in print that's how you're supposed to do it.
    It probably has to do with the load. The load being the blower wheel. On start up, since the blower wheel wants to stay at rest, it tightens up the eccentric.
    Quote Originally Posted by Red Man View Post
    You tap it so it turns in the direction of rotation, which seems backwards. Id think it should be opposite of rotation so starting torque isnt trying to loosen it. Thats what the directions say though.
    May 2013
    Quote Originally Posted by DavidDeBord View Post
    Outstanding Lahrs!
    It looks close in pic, but there is an inch gap.
    Time will tell how good my hack was. Needs to get a hotel kitchen through to the new year.
    May 2013
    Quote Originally Posted by BBeerme View Post
    Yup.
    More often than not I cut the old bearings off. Eccentric and all. Especially on the drive side which is further in on shaft. Only takes a minute.
    Often the bottom half of bearing can be left under the shaft for support as the new bearing is driven on. Less chance of damaging blower wheel.
    Yeah, I'm a hack, that grew up on a farm. A place ya had to just make stuff work.
    May 2014
    Bay Area California
    I often do the same, a cutting torch makes it go real fast.
    Dec 2012
    columbus, OH
    Pretty slick the way you fixed that...
    Feb 2016
    N'awlins Dawlin' USA and Palmares Costa Rica
    From the git er done file, I would have to put this on the Wall of Pride instead.
    Mar 2015
    Hamersville, Ohio
    Yup.
    (AC-DC Lyrics)
    Mar 2015
    Hamersville, Ohio
    (AC-DC Lyrics)
    Oct 2005
    B.C. Canada
    Defanitly wall of pride, not shame! Great fix! I would leave it, probably better than before!
    Sep 2012
    NW Louisiana
    Worthy of "Wall of Pride"!
    Very nice outside the box thinking! Uni-Strut use #1492!
    CT
