Results 1 to 13 of 24
    May 2013
    Customer didn't hear anything.
    So, we were called there due to MUA having a high discharge air temp issue. This is what one of our guys found, along with some maxitrol issues.
    Onsite maintenance hadn't heard anything out of the ordinary. :0
    I'm kind of proud of my temporary repair. Tempted to change out the other bearing to a pillar and calling it fixed.
  2. Likes dbacmc liked this post
  3. #2
    Jan 2010
    Sea to Sky
    Get er dun!
    Sent from my SM-G965W using Tapatalk
  4. Likes Lahrs liked this post
  5. #3
    Nov 2014
    Portland, Oregon, United States
    Dang! Genius!
    Sent from my SM-N950U using Tapatalk
  6. Likes Lahrs liked this post
  7. #4
    May 2014
    Bay Area California
    A York?
    If you were a real tech, you'd solder a relay on that board and call it good to go.
    I do a triple evac with nitro to remove non condensables.
    I use 56% silver on everything except steel.
    Did you really need the " If you were a real tech " ??
  8. #5
    State College, PA
    Quote Originally Posted by BBeerme View Post
    A York?
    Had a York do that to me one time. Fun times.
    Can someone please explain to me -
    Why is there never enough time to do it right the first time, but plenty of time to do it twice?
    Please view site rules: http://hvac-talk.com/vbb/showthread.php?t=1241
    Apply for Pro Membership: http://hvac-talk.com/vbb/showthread.php?t=116113
    Find your local HVAC-Talk Contractor: http://hvac-talk.com/aop
  9. Likes Lahrs liked this post
  10. #6
    May 2013
    A York?
    Engineered Air in this case.
    The concentric locking collar appeared loose when I removed what was left of the bearing. I suspect the bearing had walked on the shaft due to this.
  11. #7
    Jul 2009
    Columbia, MD
    From the looks. You are a real mechanic
  12. Likes Lahrs liked this post
  13. #8
    Atlanta GA area
    You did good...
    I repaired one of those failures last Spring... the shaft ate all the way through the bearing support.
    Seems to always happen on the belt drive side.
    Did a temp repair... ordered a whole new blower assembly... about 2 weeks later... got it going again.
    New blower is GREAT!
    GA-HVAC-Tech
  14. #9
    May 2014
    Bay Area California
    For what it is worth, there is a particular direction to lock those eccentric collars. And it is not intuitive. Done improperly, promotes further problems.
    Ask me how to do it proper.
    Quote Originally Posted by Lahrs View Post
  15. #10
    May 2013
    Eccentric, not concentric! Thanks.
  16. #11
    May 2013
    Quote Originally Posted by ga-hvac-tech View Post
    You did good...
    Totally GA. It's nearly always the drive side.
    This is from a while ago, but always makes me laugh.
  17. #12
    May 2014
    Bay Area California
    So, in your own words, how do you lock those eccentric collars in?
  18. #13
    Jul 2012
    WA
    You tap it so it turns in the direction of rotation, which seems backwards. I’d think it should be opposite of rotation so starting torque isn’t trying to loosen it. That’s what the directions say though.
