Results 1 to 12 of 12
    Caledonia WI
    Return air matters.
    Much better, and I didn't touch the supply.
    It's not what you're capable of doing that defines you, it's what you do on a daily basis.
    Jul 2009
    Columbia, MD
    Nicely done. Was the before static with the 1” filter in place?
    Athens, Ohio
    A big part was knowing that the return was the problem to start with. Nice looking work.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
    Aug 2009
    Beatrice, NE
    Why is it always a Carrier?
    Great job. It kinda looks like the supply could use some of your help or is it not that bad?
    Jan 2012
    Broomall, PA
    Quote Originally Posted by billg View Post
    Return air matters.
    I smell a new t-shirt w/slogan...
    Nice Job!!
    If I do a job in 30 minutes it's because I spent 30 years learning how to do that in 30 minutes. You owe me for the years, not the minutes.
    Caledonia WI
    Yes, a new one.
    Quote Originally Posted by gravity View Post
    Caledonia WI
    It's a rental and it is now less than .5, plus they weren't excited to spend what they already spent. The furnace is oversized (I recommend a new correctly sized one) so this is it...
    Quote Originally Posted by BNME8EZ View Post
    Jul 2009
    Columbia, MD
    Adding that 4” probably fixed most the issue. Good work. Looks good!
    Aug 2009
    Beatrice, NE
    It would be interesting to know which has a greater affect, the 4" at the bottom or the funnel at the top.
    Caledonia WI
    I thought of doing a test to see which makes more of a difference, I'll have to do it when I have more time.
    Aug 2018
    Piedmont Triad, NC
    Looks good as usual. Top notch. I can’t recall the last time I have been able to do an install in a basement. It’s been 24” closets and crawl spaces for the past few years.
    May 2014
    South Texas
    That system had a hypertension problem, you saved its kidneys. Nice job!
