    Aug 2018
    Kansas City, MO
    White Rodgers 1361-104 zone valve keeps resetting???
    White Rodgers 1361-104 zone valve problems!!!
    I have an issue with this valve rotating closed while still under a call for heat. Zone control had been retrofitted with WiFi stat from original heat only with anticipator.
    Ive only began having trouble with it recently, so Im not sure if the problems rests with just a stat compatibility issue. The valve pdf states to use heat only stat with anticipator.
    Anyone out there with similar experience?
    The holding circuit has to be resetting somehow😂
    Jul 2009
    Columbia, MD
    So youre using a wifi stat with a module powering the zone valve?
    Yes, it will work like that. Sounds like your valve is failing.
    Those valves are the worst. Replace it with something better
  3. Likes Metalman0880 liked this post
  4. #3
    Chicago area
    What voltage do you have between terminals 4 and 5 while this is happening?
