Results 1 to 4 of 4
    Dec 2018
    Carrier question
    Hello everyone my name is Ryan and this is my first post on here. I am mainly an installer but I do some service on residential units. My question is that I did a call on a Carrier furnace that was condemned by another company through a home warranty plan and we ended up getting the install. So it initially was looked at and the gas valve was getting a constant 13 or 14 volts to it even when it wasn't calling for heat but not enough to open it though. When it opened it sent the proper voltage to open it.The board was replaced and the same thing happened. When I looked at it I checked for grounding issues as well of the transformers voltages on the board. I couldn't figure out why it was doing it. I know that someone would have to be there to see it and explain it better but what are some things that could cause that to happen? It was 11 years old and a 58MXB-100-F-11116 model. It's canned I just wanted feedback on it. Thanks.
    Common of transformer not grounded.
    How were you checking voltage, what was your leads on?
    Dec 2018
    Hello. Thanks for the feedback on this issue. So the other contractor I actually know finding out from my boss and I asked him what they exactly had did and it makes sense now..
    I work for my best friend and it's a total of 3 people all together so pretty tight knit company to work for. So the other company put a used icm board that wasn't compatible with the furnace in that Carrier unit. Then they canned it but we were cheaper on the bid and got the install. The used board is all I can think of as of right now.
