Results 1 to 2 of 2
    Dec 2018
    Skytech RCT-MLT "Original" unit flame control solenoid question
    Anyone have knowledge or the original RCT-MLT Controllers ? I need to retrofit an obsolete, original, RCT-MLT controller with a newer RCT-MLT II or III model. (Old one crapped out.) I'd like to know if the original units used a 120Vac flame control solenoid, like the newer version 2 or 3 models do ? I'd like to use re-use the original solenoid, which ohms out OK. It has no label on it. Its the same size as the new 120Vac solenoids, with the only visible difference is that it has black leads and the newer ones have red.
    Moved to Fireplaces forum.
