Results 14 to 23 of 23
    Southold, NY
    Was there construction going on for those 2 years?
    Mar 2015
    Hamersville, Ohio
    Quote Originally Posted by JCBirney View Post
    Was installed in 2013 and he moved in early 2015. Have no idea who installed it. It looks like a professional job not something done by a home owner. All the sheetmetal piping and wiring is neatly done but they didn't size it right. I'm going over there this morning and get a better look at the duct work.
    Hos 4:6 My people are destroyed for lack of knowledge. Because you have rejected knowledge, I will also reject you, that you may be no priest to me. Because you have forgotten your God’s law, I will also forget your children.
    "You've got to Stand for Something or You'll fall for anything" (A. Tippin)
    We are on a "Man-made Highway to Hell", Our so called "Leaders", Political & Religious, are encouraging The Mushroom like Sheeple to go faster.
    (AC-DC Lyrics)
    Avon Lake, Ohio
    The temperature rise on that furnace should be between 62 degrees to 72 degrees regardless of what the manufacturer states. The blower cfm should be 1300 cfm. If you go by the manufactures specs the furnace would need a blower that is 2500 cfm.
    Yes, you are on the high side. Maybe high speed is needed. If it is a 3T or 3.5T blower it should probably be on High. That is not to say your duct system is undersized. Whatever speed produces the lowest flue temperature is the best speed regardless of Delta T.
    captain CO
    Check your actual static pressure. Need to move 1235 CFM to be at manufacturers higher listed temp rise.
    It has a four ton blower, so something is blocking a supply or return, or something is dirty. Or, it never really worked right.
    On the water but near the hood
    An out of spec blower motor cap will impact the rise and limit. Check it out.
    Jun 2018
    Homosassa FL
    Static pressure...... instead of guessing.
    Mn the state where absolutey nothing is allowed
    TESP and delta P readings are simple 4th grade math so..
    please post 4 single pressure readings
    before the filter
    blower compartment
    under EVAP
    above EVAP.
    taking readings in this fashion really help identify where the issue lies
    my boss thinks its possible to repeal the laws of physics
    Mar 2018
    Maryland
    did your brother have a cat that disappeared last year sometime?
    Mar 2018
    Kansas Flatlands
    Quote Originally Posted by kdean1 View Post
    What kind of filter? I hate 3M Filtrete.
    I agree that more return can only help.
    Yup, that's what it sounds like. You never said you tried a new, or different filter. You said it looked clean. How about a tabletop humidifer and white water deposits in the white filter material.Those filters look clean but are plugged up in a mater of days sometimes. Whatever, My money's on airflow on return side, measure static pressure.
    Dec 2011
    Twin Cities Minnesota
    In the right installation,been able to add another filter rack,duct to a convenient location.Done.
