Results 1 to 11 of 11
    Jun 2008
    Canada
    Cold weather manometer
    My digital isn’t worth a crap in cold weather. I occasionally need differential readings, not just positive readings. What’s the solution? Is there a u tube or incline manometer that uses glycol as a fluid? Thanks.
    Mn the state where absolutey nothing is allowed
    my boss thinks its possible to repeal the laws of physics
    Chicago area
    Magnehic gauges are good in the cold also. No fluid to mess with.
    They make compound ranges also.
    I have a -5 to +5 dual port that has served me well for over a decade.
    2310 model with the A-432 portable case kit is what I have.
    Id guess all in under 200
    http://www.globaltestsupply.com/pdfs..._datasheet.pdf
    Jun 2008
    Canada
    Quote Originally Posted by ch4man View Post
    Dang it, those u tube are a pain. Maybe I will go that way. Spose my slack tube isnt meant to take red oil?
    Jun 2008
    Canada
    [QUOTE=heatingman;25619165]Magnehic gauges are good in the cold also. No fluid to mess with.
    Sent from my iPhone using
    This is exactly what I had in mind. You use it on gas I presume? The carrying case must offer good protection, Im told dropping these will kill them?
    Jun 2014
    Dover, DE
    How cold are we talking? My Fieldpiece digital hasn’t had any issues to speak of. I’ve used it down to about 15*F.
    I havent failed. Ive just found 10,000 ways that wont work. - Thomas Edison
    Its not whether you get knocked down, its whether you get up. - Vince Lombardi
    "In this house we obey the laws of thermodynamics" - Homer Simpson
    Chicago area
    [QUOTE=Shreadhead;25619168]
    Quote Originally Posted by heatingman View Post
    Yes. I use for gas, vacuum and air testing.
    You dont want to drop them, but they handle bonking around on a shelf in the van just fine.
    Jun 2008
    Canada
    Quote Originally Posted by rider77 View Post
    -22f would be ideal. I have an sdmn 5 and Its stated accuracy is only for 32f and above. I noticed in cold weather it loses calibration/zero quickly.
    Quote Originally Posted by Shreadhead View Post
    Dang it, those u tube are a pain. Maybe I will go that way. Spose my slack tube isn’t meant to take red oil?
    if your slack tube is built for water, then no oil woint work. the oil has a different specific gravity than water.
    but..... dywer has oil slack tubs as well;
    i've never use a magnehelic so I didnt think of one. at least with either one you wont need batterys
    Jan 2002
    Chicago area, Il.
    It does expand and contact quite nicely with temperature changes, so re-zeroing as it warms up or cools off will be necessary.
    Jun 2008
    Canada
    Too bad they dont just make a different scale meant for red dye that would fit into your slack tube.
