Results 14 to 18 of 18
    Phoenix,AZ
    Looks good where it's at. If you spun it 90° the RV, OD TXV would end up against the wall and a B!tch to service.
    Mar 2018
    Maryland
    ^^^^agreed. Everything looks amazing but I’d have to agree the mastic kinda takes back a little. It looks good but not great as the rest of the install is. I avoid using mastic on the outside but when I absolutely have to I use painters tape to make my lines clean. Also if tape is done right it’s “ok” but I like the look of almost bare metal. Great job man. Those people are either really smart or really lucky to have you install their unit for them!!!
    Jul 2009
    Columbia, MD
    Did a quality check on her today. Homeowner said it was blowing cooler air. I set the stat for 2* deadband for 2nd and 3rd stage heaters when i installed. Discharging 93* air with 28* oat. Thermostat at setpoint and finishing with hp on. No issues found. Pretty much at its balance point
    Dec 2012
    columbus, OH
    Did you remove the salt spray guard from the CU?
    Jul 2009
    Columbia, MD
    Didn’t have one
