Thread: 23XRV
    winnipeg
    23XRV
    how many of you guys work on these things? I have a 575 volt input and the motor is rated for 480 volts. Having some oil return issues
    Southold, NY
    The Controller should not allow a start under those conditions!
    winnipeg
    Bitzer, Carrier have screw compressors that are specially wound to handle the increased voltage to give you increased hertz (VFD driven) so I am not concerned with the 575 volts being delivered to the motor at 100% load. The 23XRV will run up to 101 HZ at full load, I am looking for peoples experiences with them and see if they have had any oil return issues
