Results 14 to 23 of 23
    Jun 2007
    Arizona
    Quote Originally Posted by Bworth74 View Post
    Received a call on this walk in freezer another company installed. System is remoted 2 floors above box. R448 refrigerant with -10 setpoint for Freezer. Looks like this unit has an MOP txv valve at 35 psig. Has a headmaster valve for 225 psig. Unit is actually at temp but looks as if in the colder mornings and nights it may be low on charge causing this iceing issue. I will have more info tomorrow. Just wanted some initial thoughts.
    how is this defrosting ? hot gas or electric ?? how many times a day and what is the duration ?? is there any termination ? are the fans shutting off in defrost ?? more information is needed
    Aug 2018
    Fort Worth, Tx.
    Sorry still scheduling with customer to get in and make a good diagnosis. I will post as soon as I have the information.
    Oct 2011
    Harrisburg, NC
    Something interesting to note that I see when people start working with a new refrigerant.
    They seem to forget basic refrigeration diagnostic methods
    Charge, Superheat, operating pressures, defrost lengths and proper termination, etc.
    I have done a lot of work with R448a both Racks and Self contained/conventional. It runs almost the same as R22, but lower discharge temps.
    Go through from start to finish and make sure it's all operating correctly, I bet you will find the problem along the way. It's just a freezer.
    I can't fix it if it won't stay broke..
    Jun 2012
    Northern NV
    Bad CalRod at the top of the evap perhaps?
    Demand defrost or a timer?
    The ice pattern out the txv is odd
    Oct 2011
    Chicagoland Area
    I think that's just excessive moisture and nothing more
    NH
    Something I found odd with 448a was the listed defrost times from Zero Zone for a multideck med temp case was 6 times a day vs 4 times a day with 404a.
    Zero ice build up on or closer to the TXV is not odd to anyone?
    Jan 2016
    The triangle in the Keystone
    Looks like it’s been having long cycles. Could be undercharged.
    Is that element pulling out of the coil in the first pick? Is the seam on the ceiling above it separating and silicones together?
    Oct 2011
    Harrisburg, NC
    Not one bit. Means it's metering correctly to the nozzle in the distributor. If that section was frosted I'd be telling the tech to check the strainer.
