Results 14 to 22 of 22
    Oct 2018
    Dothan, AL
    Quote Originally Posted by kdean1 View Post
    Consider where Mitsubishi is made. And how many fuses they buy.
    I had to order fuses from Mitsubishi to replace some that took a hit from an electrical spike. The fuses in the Mitsubishi are a different physical size than typical automotive fuses. I also replaced an inline fan motor.
    The spike took down the buildings surge suppression and caused $10k damage to the elevator system. The bill for repairing one of about 6 ductless systems was small by comparison.
    I've got a 1960's cargo elevator at work that needs a $140k refit right now. I'll trade you.
    Sent from my SM-G930V using Tapatalk
    Athens, Ohio
    Quote Originally Posted by shaky6 View Post
    I'm happy to say it's not my building or my elevator.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
    Oct 2018
    Dothan, AL
    It's a nightmare. The building was literally built around this elevator and its SOL.
    Oct 2018
    Dothan, AL
    Well no joy. It ran for a day and then blew the same fused. Error code for communication error. Control board failure?
    Phoenix Arizona
    What is the indoor and outdoor unit model # ? And what fuses blew? F1 and F2 I would assume...
    Jun 2014
    Dover, DE
    Funny story, I spoke with a manufacturers service manager one time. In that conversation he told me around 70% of the warranty boards they got back that were reported as no good, were actually fine. And just a victim of poor diagnosis. He also thought it was amusing that many folks were quick to blame the electronics for problems that actually existed elsewhere in the system.
    So no, your board is probably ok.
    I havent failed. Ive just found 10,000 ways that wont work. - Thomas Edison
    Its not whether you get knocked down, its whether you get up. - Vince Lombardi
    "In this house we obey the laws of thermodynamics" - Homer Simpson
    Phoenix Arizona
    Typically power comes in on L1 and L2 and it turns around and goes through a fuse and out S1 and S2 to feed the indoor unit. Power on S1 and S2 goes through a inverter board and gets turned into dc to power the motor, vanes and anything else in the unit.
    So depending on the actual fuse that blew I would suspect the indoor unit or something in the wiring.
    A model number and fuse that blew would be helpful to give a 100% answer...
    Oct 2018
    Dothan, AL
    Quote Originally Posted by rider77 View Post
    I'm thinking you're probably right. That circuit connects from the noise filter board and then sends a fused 3 wire signal to the indoor unit. Really the only thing it does with the main control board is use fuse holders and a serial port. I need to diagnose it from the serial port to the indoor unit.
    Oct 2018
    Dothan, AL
    Quote Originally Posted by Hrdworkingacguy View Post
    PUZ- A42NHA2, ser # 8YU00165A
    Indoor unit is a PCA-A42KA ser # 05A00643C
