Results 14 to 17 of 17
    Aug 2009
    Beatrice, NE
    How much is the factory charge? Did you figure the extra to add for line length if thisis a split system? How much of the charge have you weighed in? And why was it removed? Was the drier changed before adding refrigerant? Are all valves open? Was the TXV ok before or was it changed?
    Nov 2018
    Saudi Arabia
    Quote Originally Posted by BNME8EZ View Post
    7 kg factory charge.
    This is packaged system,
    Almost 3 kg charge in off condition and then start the compressor and it goes to vacuum,
    Filter drier also change,
    Yes
    Southold, NY
    Quote Originally Posted by Javed Shaikh View Post
    Yes
    It needs more gas!
    Aug 2009
    Beatrice, NE
    Finish weighing in the charge and see where it goes.
    Now, remember my first post that you got upset with? I am not trying to upset you again, but I have been that senior tech I recommended for you. This is what senior techs do, lead you to a solution. So my first post was correct and I have not given you any DIY advice in the process. Now if you want to ask how you are suppose to get the rest of the charge in, sorry I can't help you, that would be considered DIY advice, but I was happy to help. The reason I suggested one on site is they could have given you some insights on the job that I can't from here and it would have been faster.
    If you need something in the future post again and we will try to help if we can.
    Also like I said earlier get your post count up and apply for pro membership, it will get you into the rest of the site, you have just scratched the surface of what this site has to offer.
