Results 1 to 13 of 37
Thread: Nothing special
    Oct 2014
    Nothing special
    Itís nothing to Fancy but Iím proud of it, I hope yíall donít burn me to bad..
    I went with 1.5 ton w/ 2 ton TAM9, I still have a couple touch ups to do on the install. They sent the wrong fire damper brackets so Iím waiting on them. We have a 1 bed/1 bath/ kitchen and living room above garage. I did run a load Calculation, it dialed in on 1.5 tons but I thought going variable speed airflow and helping maintain the CFMs across the bigger coil would give me a little bit more humidity control. Itís the first time Iíve tried this technique but I feel confident about it rather than throwing a extra 1/2 ton ďjust for the heck of itĒ the garage is unconditioned space except for a half bath. The main electrical panel is about 10-15 feet from the AH. I paid for the custom metal brackets out of pocket rather than a 2x4 shelf. I also verified with my local inspector that the blower motor housing is acceptable for fire damper access since I had no room and had to mount it so close to the unit. I am aware that this would be a complete pain to replace in the future but the builder left me with no other good options... I tried to think ahead in every way possible but Iím posting this for yíalls thoughts and opinions. Name:  IMG_2755.jpg
Size:  100.8 KBName:  IMG_2753.jpg
Size:  137.9 KBName:  IMG_3180.jpg
Size:  157.8 KBName:  IMG_3238.jpg
Size:  54.0 KBName:  IMG_3236.jpg
Size:  77.6 KBName:  IMG_3241.jpg
  2. Likes dbacmc liked this post
  3. #2
    Athens, Ohio
    It is very neat.
    Is it your usual practice to connect the primary and secondary drains?
    edit- I enlarged the picture and I see the the secondary is not connected. However, it appears the the drain is not trapped. Please let me know if I’m wrong.
    And I commend you for not upsizing it “just because.”
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
  4. Likes UrAverageAguy liked this post
  5. #3
    Southold, NY
    Very Nice.
    What the black shiny tape? on the armor flex?
  6. #4
    Jul 2009
    Columbia, MD
    What kind of thermostat is that?
  7. #5
    Jan 2012
    Broomall, PA
    How did it get rocked/taped (top/back) after the fact?
    If I do a job in 30 minutes it's because I spent 30 years learning how to do that in 30 minutes. You owe me for the years, not the minutes.
  8. #6
    Oct 2014
    Quote Originally Posted by kdean1 View Post
    It is very neat.
    edit- I enlarged the picture and I see the the secondary is not connected. However, it appears the the drain is not trapped. Please let me know if Iím wrong.
    And I commend you for not upsizing it ďjust because.Ē
    The secondary port has a inline float switch thatís capped off. I do have a trap but was worried it might drip water on his work bench this summer so I insulated the drain line.
  9. #7
    Oct 2014
    Very Nice.
    I didnít have anymore glue for the insulation and settled for tape but was regretting it after doing so..I hate the way tape looks
  10. #8
    Oct 2014
    Quote Originally Posted by gravity View Post
    Acont624. The 824 is better and the 1050 is the betterest. Great thermostats
  11. #9
    Oct 2014
    Quote Originally Posted by STEVEusaPA View Post
    The top is rocked but they couldnít get behind it. The drywall stops at the top of the bracket. Is it bad to say that I wanted the unit in place before they put the drywall up.
  12. #10
    Athens, Ohio
    If I had my way, the equipment wouldn’t go in until the drywall was finished. If it’s not there they can’t use it during construction.
  13. #11
    Oct 2014
    If I had my way, the equipment wouldnít go in until the drywall was finished. If itís not there they canít use it during construction.
    I thought about it but the support brackets had to go in first either way and once they were in place I knew that was my best opportunity to seal my duct connections, and no I didnít screw anything together that you canít get to right now. Might have to rip some tape but thatís it. I also left the unit disabled until after the clean up was done and screwed wood over the vents
  14. #12
    Jan 2014
    New England
    Where's the shut off switch for the AH? as the sealtite looks to me anyway to go directly into the AH.
  15. #13
    Oct 2014
    Quote Originally Posted by Bazooka Joey View Post
    The main breaker panel is about 10í away from the unit.
