Page 6 of 6 FirstFirst 123456
Results 66 to 73 of 73
  1. #66
    Apr 2003
    Greenback, Tennessee
    Quote Originally Posted by EugeneTheJeep View Post
    Mars, made in the USA.
    Correction: Mars are assembled in the USA. Titan HD and Amrad made in the USA not just assembled in the USA.
    -Marty
  2. #67
    May 2009
    Earth
    Quote Originally Posted by m singer View Post
    Mars uses BMI.
    http://www.bmicaps.com/
  3. #68
    May 2018
    FLORIDA
    i'm wondering if Titan HD are BMI too
  4. #69
    May 2018
    FLORIDA
    Anyone know who make TITAN HD capacitors ??
  5. #70
    Feb 2019
    This is a question asked by many beginners. I will give you a simple answer to this question without going into all the details. After reading this, my goal is that you should be able to go and find the capacitor you need right away.
    I have also written about how to choose capacitor values that I recommend you check out.
    Different capacitor types
    Polarization
    First of all, we boil it down to two capacitor types:
    Polarized capacitor
    Non-polarized capacitor
    The difference between a polarized capacitor and a non-polarized capacitor is that the polarized capacitor has a positive and a negative side. So it must be placed with the positive pin where the most positive voltage is. You can place the non-polarized capacitor in any way you want.
    Do you need a polarized capacitor? Or a non-polarized capacitor? To figure this out, look at you schematic diagram. What capacitor symbol is used?
    These are non-polarized capacitors:
    Schematic Symbols Capacitor US Style
    These are polarized capacitors:
    Polarized capacitors
    If you need a polarized capacitor, you need something called an “electrolytic” capacitor. There are two types of electrolytic capacitors:
    Aluminum
    Tantalum
    Aluminum
    The most common is the aluminum capacitors. It is also the cheapest of the two. Aluminum caps usually come as through-hole components. But you can find some surface mount versions of it as well. Choose aluminum caps unless you have any special requirements.
    electrolytic-capacitor
    Tantalum
    If you need a smaller and more durable capacitor, you should choose the tantalum type.
    Tantalum caps are available in small surface mount packages. They can work in a wide temperature range. Note that some tantalum caps come in non-polarized version also.
    Tantalum capacitors
    Non-polarized capacitors
    If you need a non-polarized capacitor, look for either a ceramic or a film capacitor.
    Ceramic caps are small and cheap. It’s the most common choice for non-polarized capacitors. They are often used as decoupling capacitors.
    Ceramic capacitors
    If you have any special requirements like low tolerance, high reliability or a capacitor that is able to operate under high temperatures, then choose a film capacitor. It is much better for this.
    Film caps can be made of polystyrene, polycarbonate or Teflon. They each have their own properties, but that is out of the scope of this page.
  6. #71
    May 2018
    FLORIDA
    Quote Originally Posted by niamishra View Post
    Polarization
    Polarized capacitor
    Aluminum
    Tantalum
    Aluminum
    Tantalum
    Tantalum capacitors
    Ceramic capacitors
    I didn't ask for anything, and i'm not a beginner !!
  7. #72
    Oct 2005
    Oregon
    Quote Originally Posted by AIRCON8 View Post
    That's funny. I just read the entire thread and you asked the same question about 5 times and multiple other questions. To make a statement that you didn't ask for anything is crazy.
  8. #73
    May 2018
    FLORIDA
    funny
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
