+ Reply to Thread
Page 4 of 6 FirstFirst 123456 LastLast
Results 61 to 80 of 115
Thread: WHAT BRAND OF CAPACITOR DO YOU CARRY ???
  1. #61
    May 2018
    Miami
    Quote Originally Posted by HVAC_Marc View Post
    who - your oncologist
    why - prolonged exposure often result in cancers of various types
  2. #62
    May 2018
    Miami
    i guess PCB oil just don't work well as main component for capacitors.
  3. #63
    May 2009
    Earth
    PCB capacitors were the best, they were self healing.
  4. #64
    May 2018
    Miami
    so why Amrad las so long ??
  5. #65
    Feb 2017
    Canada
    Quote Originally Posted by AIRCON8 View Post
    https://www.youtube.com/watch?v=b_fW148JesA - HVAC Run Capacitors Factory Tour
  6. Likes R600a liked this post.
  7. #66
    Apr 2003
    Greenback, Tennessee
    Quote Originally Posted by EugeneTheJeep View Post
    Mars, made in the USA.
    Correction: Mars are assembled in the USA. Titan HD and Amrad made in the USA not just assembled in the USA.
    -Marty
  8. #67
    May 2009
    Earth
    Quote Originally Posted by m singer View Post
    Mars uses BMI.
    http://www.bmicaps.com/
  9. #68
    May 2018
    Miami
    i'm wondering if Titan HD are BMI too
  10. #69
    May 2018
    Miami
    Anyone know who make TITAN HD capacitors ??
  11. #70
    Feb 2019
    This is a question asked by many beginners. I will give you a simple answer to this question without going into all the details. After reading this, my goal is that you should be able to go and find the capacitor you need right away.
    I have also written about how to choose capacitor values that I recommend you check out.
    Different capacitor types
    Polarization
    First of all, we boil it down to two capacitor types:
    Polarized capacitor
    Non-polarized capacitor
    The difference between a polarized capacitor and a non-polarized capacitor is that the polarized capacitor has a positive and a negative side. So it must be placed with the positive pin where the most positive voltage is. You can place the non-polarized capacitor in any way you want.
    Do you need a polarized capacitor? Or a non-polarized capacitor? To figure this out, look at you schematic diagram. What capacitor symbol is used?
    These are non-polarized capacitors:
    Schematic Symbols Capacitor US Style
    These are polarized capacitors:
    Polarized capacitors
    If you need a polarized capacitor, you need something called an “electrolytic” capacitor. There are two types of electrolytic capacitors:
    Aluminum
    Tantalum
    Aluminum
    The most common is the aluminum capacitors. It is also the cheapest of the two. Aluminum caps usually come as through-hole components. But you can find some surface mount versions of it as well. Choose aluminum caps unless you have any special requirements.
    electrolytic-capacitor
    Tantalum
    If you need a smaller and more durable capacitor, you should choose the tantalum type.
    Tantalum caps are available in small surface mount packages. They can work in a wide temperature range. Note that some tantalum caps come in non-polarized version also.
    Tantalum capacitors
    Non-polarized capacitors
    If you need a non-polarized capacitor, look for either a ceramic or a film capacitor.
    Ceramic caps are small and cheap. It’s the most common choice for non-polarized capacitors. They are often used as decoupling capacitors.
    Ceramic capacitors
    If you have any special requirements like low tolerance, high reliability or a capacitor that is able to operate under high temperatures, then choose a film capacitor. It is much better for this.
    Film caps can be made of polystyrene, polycarbonate or Teflon. They each have their own properties, but that is out of the scope of this page.
  12. #71
    May 2018
    Miami
    Quote Originally Posted by niamishra View Post
    Polarization
    Polarized capacitor
    Aluminum
    Tantalum
    Aluminum
    Tantalum
    Tantalum capacitors
    Ceramic capacitors
    I didn't ask for anything, and i'm not a beginner !!
  13. #72
    Oct 2005
    Pacific Northwest
    That's funny. I just read the entire thread and you asked the same question about 5 times and multiple other questions. To make a statement that you didn't ask for anything is crazy.
  14. #73
    May 2018
    Miami
    funny
  15. #74
    Oct 2013
    I am aware that this one is an old thread. but...
    Almost 5 years ago, I replaced the original 19 yo GE Capactor in my unit, because it was reading a lil under. I used the Genteq with the same part number as the GE capacitor. Well, the replacement failed after 1769 days, which would roughly come up to 15,000 hours of actual use. The box on the Genteq indicated 60,000 hour reliability.... yeah right.
    After 4 years the top of the Genteq was all rusty. I cleaned it and applied a clear coat to protect it.
    To get the unit running I used the 19 yo capacitor which I had kept. Now I am trying to find a better replacement
  16. #75
    Virginia
    Capacitors are designed to fail now
    Get used to it
    Trade Pro , Amrad , are good caps , but dont expect any where near 19 years
    Tell your Cat I said "Psst Psst Psst"
    It seems like everywhere I go the AC is broken
  17. Likes R600a liked this post.
  18. #76
    Jan 2010
    Go back to PCB's 😉
  19. Likes EugeneTheJeep liked this post.
  20. #77
    May 2018
    Miami
    Jul 2018
    Wisconsin
    Light bulbs are designed to fail. Capacitor mfgs. Followed
    Sent from my SM-S908U using Tapatalk
  22. Likes R600a liked this post.
  23. #79
    R600a's Avatar
    R600a is offline Professional Member*/Membership Committee
    Jul 2019
    Hanging out with the mice behind the fridge talking bad about the roaches in the oven.
    Quote Originally Posted by Spitz View Post
    All manufacturers followed with the possible exception of manufacturers of things like the Mars rovers and space station component manufacturers.
    "Is this before or after you fired the parts cannon at it?" - senior tech
    I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
    Unless we change direction we are likely to end up where we are going.
    "It's not new, it's better than new!" Maru.
  24. #80
    Oct 2013
    Thanks for the your suggestions.
    Amrad did not have the capacitance I needed in the size that fits nicely in the unit.
    I decided to try BMI capacitors. Their literature is excellent, and they supposedly meet EIA546A.
    https://www.bmicaps.com
    I found this article helpful:
    https://www.ien.com/product-developm...ing-capacitors
    Time will tell.
    lol @ "tell your cat..."
  25. Likes EugeneTheJeep liked this post.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
