Results 1 to 8 of 8
    Jul 2014
    London
    Kitchen heat recovery for the purpose of DHW (pre-)heating
    Hello HVAC community,
    I am looking for reliable and hassle free heat recovery system for commercial kitchens.
    I would like to use for the purpose of (pre-)heating hot water.
    All solutions that I found so far get clogged up with grease relatively quickly and had to be remover shortly after installations.
    I wonder whether you have heard / have experience with any heat recovery system that works properly in the kitchen environment?
    Kind regards
    dolph82
    Jul 2018
    Wisconsin
    Look up PowerPipe. I believe they sell it a Home Depot. Only issue I could see with this is the pressure drop thru the heat exchanger.
    Sent from my SM-G920R4 using Tapatalk
    SE Iowa
    I don't see any solution that won't clog up that would transfer any meaningful percentage of heat to get a payback. Plus a lot of the energy is latent heat, so you'll have a condensation and frost issue as well.
    Honestly, if you have the newer style hoods with makeup air at the point of exhaust, you mostly eliminate the preheat requirement for the makeup air.
    Jan 2010
    Sea to Sky
    How many walk in coolers and freezers do you have? We can install a small refrigeration rack with heat reclaim.
    Kidding.....a little cost prohibitive.
    Sent from my SM-G965W using Tapatalk
    Madison, WI/Cape Coral, FL
    Here is a guy from the past with a new address. Going after the kitchen heat is tough. There is a lot of grease involved.
    The heat from your coolers and freezers is much hotter and may heat most of your water.
    There are used by many.
    https://www.thermastor.com/heat-recovery-water-heaters/
    How did that attic in Iowa turn out?
    Regards Teddy Bear
    SE Iowa
    I ended up moving to Michigan. Bought 2 homes there. Replaced 1 AC and furnace and downsized it in half. Super comfortable now. Then moved back 2 blocks away from my previous house. Now I have a 1 pipe steam vapor system that I’ve got purring like a kitten at <0.5oz with 2 heat pumps systems added for central air and shoulder season. It’s a 1905 3300sqft brick victorian. Full basement with cut stone foundation. Original windows. Full unfinished attic with 13’ ceilings in the middle.
    Have another unvented attic. Try something different that I’ll have to detail at a later time.
    Big news is I’m seriously looking at finally becoming a service tech. More on that later.
    May 2014
    Bay Area California
    Quote Originally Posted by Spitz View Post
    Do they have Home Depot in London?
    I do a triple evac with nitro to remove non condensables.
    Apr 2003
    St. Louis
    https://www.google.com/shopping/prod...174,num:4,cs:1
    And there are different sizes. Problem i see is the contact of the drain water and the time of contact running through and total surface area being touched. Piping it in a trap configuration might create drain problems with the drain system.
