Results 1 to 13 of 27
Thread: Nice access
    Jul 2018
    Wisconsin
    Nice access
    People who design/install dont give a F about the service guy. Hope the wire chase is well supported
    Sent from my SM-G920R4 using Tapatalk
    Nov 2014
    Portland, Oregon, United States
    No words buddy..
    No words.
    Sent from my SM-N950U using Tapatalk
    Athens, Ohio
    A sawzall will make quick work of those pipes and conduits.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
    Jul 2018
    Wisconsin
    Typical for this location, return VAV box for a O.R.
    Oct 2007
    Austin Texas
    That looks pretty good. I had a nightmare getting to a air tube transfer box last night.
    Nemo me impune lacessit.
    How much blood do I have to bathe in to get clean?
    Don't look down on anyone unless you're helping them up.
    Jul 2018
    Wisconsin
    Quote Originally Posted by John Culpepper View Post
    We have a humidifier to repipe. Has been incorrect since it was installed in 2012. Installing contractor fixed it by shutting the supply to it.
    Oct 2007
    Austin Texas
    I work in a hospital too. When I get a cold room call, the first thing I have to check is that someone didn't valve off the water to the reheat coil in the vav.
    Jul 2018
    Wisconsin
    Then you turn it on something leaks or the valve doesn't work. Thats how alot of maintenance/hvac guys work.
    Jan 2013
    Central Arkansas
    saw to coveralls and booties and 1st thought was a OR, yep I work in hospital maintenance, at least there is a lot of room to get around. I have seen above ceilings where you just can't get to anything.
    Jul 2018
    Wisconsin
    I've seen walls built around VAVs in hospitals. VAVs installed upside down. Fan powered VAVs with sprinkler pipes pushing against the bottom and no access to the top. You need to get creative to work on them sometimes. The tinner who hangs them must have a good laugh.
    Oct 2007
    Austin Texas
    Quote Originally Posted by Spitz View Post
    Yeah, then I get to cut out a gate valve and propress in a ball valve. Then cross my fingers that the actuator works.
    Oct 2007
    Austin Texas
    I have seen the same. They are constantly moving walls around, and I have to figure out which thermostat controls what area. Not to mention I have three different control systems running everything.
  13. Likes Spitz liked this post
  14. #13
    Jul 2018
    Wisconsin
    Had a humidifier that the condensate wasnt draining. Ended up cutting into the 3/4" condensate line. They used I would guess schedule 180 EX pipe maybe heavier. We use all schedual 80 pipe/fittings for steam. The ID of the pipe installed was around a 1/4". Never figured why they used that pipe for 10lb steam.
