Results 14 to 15 of 15
Thread: VOC Elimination
    Madison, WI/Cape Coral, FL
    Any organized fresh air ventilation? Most suggest a fresh air change in 4-5 hours when the home is occupied with normal materials in the home. Without fresh air change, the home will vary with VOC levels depending on operation of exhaust devices, stack effect, and wind.
    Keep us posted.
    Regards Teddy Bear
    Dec 2015
    Austin
    Quote Originally Posted by teddy bear View Post
    Keep us posted.
    Regards Teddy Bear
    Teddy - Your advice has been invaluable to me over the years and there is no doubt fresh air intake is the fastest, surest way to bring down VOC levels.
    But in the case under discussion I think a VOC test is indicated. Readings of 1000 - 3000 ppb are huge and troubling. I have doubts on the accuracy of consumer VOC meters but the readings should be confirmed.
    One thing to keep in mind is that VOCS boil at temperatures much higher that ambient levels. So if VOCS are present in the air then they are off gassing from liquids from surfaces. Fresh air intake will quickly resolve the VOCS in the air but will not eliminate the source. With the high levels reported I think a VOC test is the next step and Fresh air asap.
