+ Reply to Thread
Results 1 to 11 of 11
Thread: Nightmare on Elm St.
    north suburbs of Chicago
    I've been to this headache before and always cringe when they call. Luckily it was just an old screw fuse toggle switch not making! Also lucky they sprang for one shut off valve to isolate the ruptured Extrol. A couple weeks later he wanted me to reroute a supply and return for a second floor loop that was in the way of the larger electric panel he was having installed all due to one thing leads to another when a kitchen cabinet fell down.
    Second floor loop NO WAY to get air from it. Radiant loop also no way to bleed air. I guess as long as it eventually moved into the old standing radiation they finally eliminated it. Oh and when the FB8 naturally did not work I was able to pick up a 5/16 refrigeration to 1/2 MPT adapter that sat in the supply house for a century. Yes 5/16 hard copper from feed valve to boiler. Thank god the second floor loop had supply and return shutoffs so I could install what I needed to blow it down.
    [IMG]Nightmare by Glenn Hanson, on Flickr[/IMG]
    And the radiant mixing valve with the outdoor portion nowhere to be found.
    the other end must be some place or someone cut it off not knowing what it was for
    Not sure what happened to the other pic
    Mar 2015
    Hamersville, Ohio
    Is that Induced draft/ flue set up "Kosher"?
    Hos 4:6 My people are destroyed for lack of knowledge. Because you have rejected knowledge, I will also reject you, that you may be no priest to me. Because you have forgotten your God’s law, I will also forget your children.
    "You've got to Stand for Something or You'll fall for anything" (A. Tippin)
    Mat_15:24 But he answered, “I wasn’t sent to anyone but the lost sheep of the house of Israel.”
    this whole boiler set up looks DIYED to me was it needs to be redone one part at a time and done right
    Poodle Head Mikey's Avatar
    Poodle Head Mikey is offline Membership Chair/ARP Committee / Professional Member*
    I try to stay as far away from myself as I can.
    I'd tighten the coat hanger on that x-trol tank.
    PHM
    Quote Originally Posted by Glennhvac View Post
    PHM
    When faced with the choice between changing one's mind, and proving that there is no need to do so, most tend to get busy on the proof.
    Quote Originally Posted by pctech View Post
    I have told them that for about six years. It all has to go and be redone the right way. I have also told them don't start waiting till the thing cracks on Friday night in December. Probably a three day job ideally in warm weather.
    Mar 2015
    Hamersville, Ohio
    Glenn, hopefully you have made up your Invoices in such a manner, that it relieves you of any responsibility, if a situation arises that causes Harm to Body &/or Property.
    Apr 2004
    Waterloo N.Y.
    That's where I left my Channel Locks! I thought somebody stoled them!!!
    There's TREACHERY AFOOT!!!
    is that your extra xtrol tank on the floor to ?
    i love the hacked in draft inducer for the chimney vent system how it works right is beyond me
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
