Results 1 to 13 of 16
    Jul 2009
    Columbia, MD
    New 2.5ton hp with furnace
    Replaced my buddies 2ton ac and 40k propane furnace to a 2.5ton hp with 60k furnace. Only 5 years old. Propane bills thru the roof and the old carrier furnace wouldn’t put out anymore then 100*.
    Added new 4” filter and wrapped all the supply ductwork.
    Had to widen the stand outside. Used strut to brace it and bolted the pad to the strut
    Jul 2009
    Columbia, MD
    Jan 2014
    New England
    Myself I would have installed drier by AH and ran soft drawn liquid line then through wall to make braze joint existing LL or ran new LL soft drawn to me would have looked a little cleaner plus eliminate three braze joints and two copper elbows. To me the drip leg on the gas pipe is more than adequate. But hey that's me...
    As long as the customers happy....
    Oct 2014
    I like it, looks clean and neat. I also like that you sold your buddy a dual fuel, if he’s saving money then that’s extra beer money. Would’ve been nice to see some before pictures though.
    Jul 2009
    Columbia, MD
    Everything pretty much lined back up. I had to move the return duct 4” back. Tied gas back in, the old fit right up.
    Im in the commercial world so, extra fittings dont bother me. Nitro was purged while brazing.
    Lineset stayed and old was 410a.
    Oct 2014
    Columbus, Ohio
    Was the old unit condensing or not? If not, the change from 40k standard efficiency BTU to 60k high efficiency BTU is probably gonna be way more than he needs, right? That would be 25k additional output BTUs if the new unit is 95%.
    Jul 2009
    Columbia, MD
    Old furnace was condesing
    Please tell me you cut the extra length off the bolts that hold the stand to the building other then that nice work
    State College, PA
    I really like wall mounting condensers when I can.
    Nice clean work. Wish mine looked that good.
    I'll keep practicing.
    Can someone please explain to me -
    Why is there never enough time to do it right the first time, but plenty of time to do it twice?
    Please view site rules: http://hvac-talk.com/vbb/showthread.php?t=1241
    Apply for Pro Membership: http://hvac-talk.com/vbb/showthread.php?t=116113
    Find your local HVAC-Talk Contractor: http://hvac-talk.com/aop
    Aug 2009
    Beatrice, NE
    Looks good. I do have a couple questions.
    I understand the need for drainage on the heat pump but if your on a bracket do you need the legs? I don't like brackets but they do have their place. I figure the bracket gives all the space needed for drainage except for some spacers under the unit for drainage from under the unit.
    Where does the vent for the drain line go, I assume it is draining something else. I always try to keep an air gap separating everything going into the drain so if one device plugs it doesn't back up into another.
    It is a nice looking install, just wondering why people do what they do.
    Jul 2009
    Columbia, MD
    If the unit sits on the pad, there is no room for water to drain out. Unless, i took the fan off snd drilled holes from the inside of the unit down thru the pad.
    So the pump ups let water drain from under the unit.
    The “vent” is from the air conditioner in the attic.
    My buddy did the stand outside while i did the furnace inside. I don’t think he cut the rod.
    i would the next time you go do a service call i would the excess length would drive me nuts its an appearance thing
    Aug 2009
    Beatrice, NE
    Quote Originally Posted by gravity View Post
    I understand this. My point is water won't build up on the pad so you don't need as much space between the pad and unit for drainage, a 3/4" rubber pad should be adequate. It is not like when a pad sits on the ground where snow & ice can build up around it. I have never seen a raised pad like that with over 1/4" of ice on it so why raise it so high?
