Results 1 to 10 of 10
    Nov 2018
    split ac installing without evacuating
    hello guys.
    I install 1hp split ac in my house. Panasonic brand and refrigerant is r410a
    but i install it without vacuum the pipe before i on the ac
    now the ac can run without any problem. but i scared that in future it make any problem
    can tell me what are the possible problem will cause if install without evacuation
    what should i do now if i want to avoid that problem?
    Southold, NY
    Purchased on line.
    Not following best industry practices.
    No certification in handling or using refrigerants.
    Let it run, it will die a slow death
    Jun 2008
    west point, ga.
    Kinda wondering if this was actually a joke. If not then the system will give plenty of problems. Just because it’s running doesn’t mean it’s running right. Would really recommend hiring a contractor to fix EVERYTHING. Good luck.
    Nov 2018
    is that there is other solution other then purchasing new one?
    like evacuate the ac and add refrigerant?
    Southold, NY
    Quote Originally Posted by Saraweshwaran View Post
    What does your training tell you?
    Nov 2018
    I didn't go any training centre before i install the AC
    I only install ac in my house.
    Athens, Ohio
    Yeah. Our profession is not something that can be learned from an online post, or even an online course.
    You'll need to ask a local contractor to rectify what you have done.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
    Jun 2014
    Dover, DE
    Your unit is headed towards failure. Failure of the unwarranted type.
    I havent failed. Ive just found 10,000 ways that wont work. - Thomas Edison
    Its not whether you get knocked down, its whether you get up. - Vince Lombardi
    "In this house we obey the laws of thermodynamics" - Homer Simpson
    Prata di Pordenone
    ahh it won’t hurt it , let it run
    Go Trump
    It should be recovered, vacuumed and recharged with virgin refrigerant.
Tags for this Thread
