Results 14 to 16 of 16
    Home Energy Products: 170 DW Hwy, Belmont, NH 03220
    Our distributor sold us the GPS IWave-M after telling us they had good feedback on them. They are relatively expensive and I think we would have some customer grousing, especially on newer systems. I noted Randy's comment on their testing. We have not has a DSS complaint since we bought a couple. If we could install one in a continuously stinky unit, and it quickly got rid of the smell I may be convinced. I would not be surprised to get the chance this spring, which is when we get most complaints.
    Madison, WI/Cape Coral, FL
    This is too complex. Follow ASHRAE with basic fresh filtered (+11 merv) air change is 3-4 air changes per hour when occupied. This will purge indoor pollutants and renew oxygen.
    Maintain <55%RH in the home. This avoid dust mites/mold.
    For most this is all that is needed.
    For very sensitive move on to a higher levels like you are discussing.
    Most small particulate settles to the floor before reach a good filter. A vac with a good filter or outside exhaust is a big help.
    We see all this complexity and house does not fresh air ventilation or good humidity control. A waste!
    I have been your route. Get the basics right first.
    Regards Teddy Bear
    Dec 2015
    Austin
    Quote Originally Posted by hepservice View Post
    DSS is biological, so previous remarks about VOCs may not apply.
    You might want to check these guys. They have some unique UVC approaches that I've heard good things about.
    Apparently all UVC installations are not equivalent.
    https://www.steril-aire.com/
