Results 1 to 8 of 8
Thread: New CW Coil
    Jul 2018
    Wisconsin
    New CW Coil
    Swapped out a CW coil a few months ago.
    Sent from my SM-G920R4 using Tapatalk
    Nov 2014
    Northern Idaho
    Thanks for posting. Why black iron, is that what the connections on the coil are made out of?
    Jul 2018
    Wisconsin
    Connections were 2.5" threaded reduced to 2". No real reason for the Iron fittings on the top connection. Was told to go pipe it and given a box of fittings and it just worked out.
    Southold, NY
    Nice job....
    You need a Pro Press!
    Jul 2018
    Wisconsin
    We have one up to 2" its looks so much better soldered. Not sure a would have been able to fit all those PP fittings in there and keep it plumb. I used a street male adapter also good luck finding one in stock thats PP.
    Jul 2018
    Wisconsin
    Nice job....
    Face to face on a 2" PP fitting you are suppose to leave a 3/4" space.
    New Jersey
    Nice clean work, but you should not connect black iron directly to copper. You could use a dielectric union to avoid the possible reaction from the different metals.
    Sent from my ASUS_P00J using Tapatalk
    Jul 2018
    Wisconsin
    Is it still a concern with a closed loop and chemical treatment? The coil manufactures use a steel header and copper passes on the coil.
