    Jun 2008
    Two 100 pound tanks gas tanks empty without use.
    So in a week my two hundred pound gas tanks went empty with almost no use of the fireplace. Also I noticed the carbon monoxide detector went off a few times. So I have a leak. Should I use soap and water to check for a leak?
    SE Michigan
    Yes, you can use soap bubbles to locate the leak or leaks.
    You should be able to almost Hear a 200 lbs. per week leak. <g>
    But yes; just use soap. There are special soaps for the purpose but children's bubble-blowing soap will work well.
    Can you smell raw propane inside your fireplace?
    PHM
    Quote Originally Posted by edteach View Post
    PHM
