Results 1 to 13 of 23
    Oct 2018
    Trane HP with Comfortmaker AH controlled by Honeywell T4 Pro Thermostat
    Trane HP Model - 4TWR4036G1000A
    Comfortmaker AH - FSM4P3600A
    Honeywell Thermostat - TH4110U2005
    I'm a new tech. I'm having a problem with the 5 amp fuse blowing whenever I switch to heat. Everything works fine in AC mode. I could use some advice please.
    P.S Im not doing this for a customer. Im doing this in my own home. This is the first Trane HP I've worked on.
    And what have you checked so far.
    Southold, NY
    Short of just replacing the fuse what else!
    What does your meter tell you?
    Define New Tech?
    Oct 2018
    So far I've eliminated the circuit board being bad. I know its not the OD unit because its brand new. Now I'm confused with the blue wire coming from the defrost board. From what I've read and Trane's, this wire is the common wire correct?
    Southold, NY
    A wise man once taught me "Electrons know no color"
    Forget the "Blue" wire what terminal on the board and where does it go?
    Southold, NY
    Quote Originally Posted by Rcameron24 View Post
    Thats guessing not troubleshooting.
    Grab your meter and troubleshoot
    Oct 2018
    Define New Tech?
    I only have a 1 year of field experience
    Southold, NY
    I sought of guessed that
    Grab your meter and begin tracing out the circuit by following the diagram.
    Oct 2018
    Thank you
    Oct 2018
    I know I have one of my thermostat wires going to the wrong terminal. Im not guessing that. The thermostat doesn't have a separate terminal for O and B. It's labeled O/B at the terminal. I'll figure it out. Thanks everyone. Enjoy your Sunday
    Southold, NY
    Its labeled O/B because the program decides when to energize!
    Please be careful!
    Oct 2018
    Please be careful!
    I got that. I'm trying to figure out what to do with the B wire. My old HP was a Comfortmaker/Carrier unit. Five wires from the unit to the air handler. R,C,O,W,Y. This is my first time working with a Trane HP.
    Southold, NY
    Forget the colors
    Print out the wiring diagram and follow the wires. Find out what components are protected by the fuse and ohm out each one. Ohm out the wires. Follow the circuits!
