The problem you are having is not abnormal. Your calculations are correct. You will get better results with an inclined manometer because you can mentally average the readings. The problem is lack of continuity of mass which results from the low pressure of the fan. As your readings indicate the airflow is not stable.
I wish I had better words to explain this but don't.
