Thread: KMC Bacstage
    Oct 2018
    KMC Bacstage
    We have a client that has KMC BACnet controllers installed for their HVAC system. We are trying to access it using the BACstage program and the HASP key, but nobody has the password for the system. Is there a default password to be able to get into this control program?
    Thanks in advanced
    Greater Atlanta Area
    The password is assigned when the software is installed.
    Mar 2018
    Quote Originally Posted by controlgeek View Post
    Think this is right, when the software is installed you pick a password, if the software is there Id grab any backups from the program data folder, and reinstall it. If not would try calling KMC their tech support is usually very helpful.
    Apr 2005
    Australia : Queensland
    Pull it out & put New User Friendly Control Gear in.
    The previous outfit has tried to lock themselves into the site by using.
    The primary function of the design engineer is to make things difficult for the fabricator and impossible for the serviceman.
    Mar 2018
    Quote Originally Posted by fridg View Post
    Id hope no customer would be stuck with it as a front end, wouldnt think so, its really just a configuration tool. If this is on a tridium supervisor there are free modules that allow configuration from the tridium wb which by passes bacstage.
    Apr 2005
    Quote Originally Posted by bolt950rider View Post
    Tridium here in OZ is license controlled. The End User Only gets limited access ,, virtually locking the installer in if you dont have the Software.
