+ Reply to Thread
Results 1 to 6 of 6
Thread: Randell custom make table w/ cold rail
    Mar 2017
    So I’m hoping someone has came across this issue before and knows of a repair other than incorporating a welder. We have a restaurant we service that uses the Randell custom make tables and has all of the cold rails as a system to a remote refrigeration rack. We installed ball valves and confirmed one of the cold rails has a bad leak on it. Is there any way to make a repair on the evaps other than complete unit replacement or using a welder to disassemble everything?
    Aug 2013
    Omaha
    No unless u experiment and cut into the side of the rail...but by that point you've torn up the insulation, etc.
    I wouldn't recommend it
    Sent from my SM-N920V using Tapatalk
    Mar 2017
    I figured, I was giving it a shot Incase someone figured out something
    Jan 2010
    Where did you install the ball valves ?
    Mar 2017
    Right before txv inlet just after LLSV and suction line about 12” or so after exiting evap. It’s a very small area to do any work in about 6” opening
    Aug 2009
    Maine
    This is a good place to try stop leak. (:-
  7. Likes SkullMonkey liked this post.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
