+ Reply to Thread
Results 1 to 10 of 10
Thread: Ruud Furnace Ignition Issue
    Oct 2018
    working on a ruud silhouette ii model number UGPH-07EAMGR furnace with an ignition issue. unit cycles properly, blower, pressure switch closes, gas valve opens but no spark for the ignitor. checked post on board for the ignitor with a wire to ground and got a single spark out of it during the ignition cycle. assumed it was the ignitor and replaced it, no luck. could the lack of a pulsating spark from the board be the result of a bad ground? also, the unit had had a freeze up issue due to dirty filter, created a lot of condensation which may have dripped down into the unit. Thoughts?
    SE Ohio
    We cannot give technical advice in the AOP forum.
    https://www.hvac20.com/ High efficiency equipment alone does not provide home comfort and efficiency. HVAC2.0 is a process for finding the real needs of the house and the occupants. Offer the customer a menu of work to address their problems and give them a probability of success.
    Find contractors with specialized training in combustion analysis, residential system performance, air flow, and duct optimization https://www.myhomecomfort.org/
    Is it a spark or hsi ignition?
    Oct 2018
    It is a spark ignition.
    Mar 2018
    Kansas Flatlands
    Quote Originally Posted by jmiller0394 View Post
    Stay away from the ICM aftermarket board. Go OEM.
    Chicago area
    If you had a wire to case ground and held other end to the spark terminal, and no sparky, then the board is the issue.
    The spark will overcome a lousy ground and some bad connections. The spark needs to jump an air gap and will.
    Oct 2018
    Thanks for the reply.
    There is a single spark only. It doesn’t repeat or continue to spark say for 5 seconds or so. It doesn’t light with the single spark. I can light it during that cycle with a lighter and everything fires up, so I know the other interlocks are working. Sounds like the board is bad or going bad, correct?
    Yes OEM for sure.
    SE Ohio
    What have you learned about it by testing with a meter?
    If it sparked once , it can surely spark 100 times , so im going with board bad
    SE Ohio
    You have not given us anything in the way of a measurement. A real tech would give us some.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
