Results 1 to 10 of 10
    Oct 2018
    Confused I was told my furnace/ac were installed incorrectly and should be replaced
    I'm a first year, first-time homeowner who never had to deal with furnaces before. I had a Home Depot furnace tune-up special so they could replace the filter.
    I was told the furnace is backwards, the filter was in the wrong place and the ac (added a few years after the townhouse was built) should be on the bottom of the furnace not the top. They took the filter out and did not replace with a new one as it could be a fire hazard.
    The townhouse was built in 2000, the furnace is original but runs perfect still, the home inspector didn't note anything wrong. The ac and heater run to my liking. But it's going to be a low of 13 degrees tommorrow and I dont have a filter in my furnace so I'm afraid to run it.
    The furnace is in a maintenance closet on the second floor. The home has the air vents at the top of the walls. There are also floor vents only on the second story. I noticed that when I ran the ac unit this summer, the cold air only flowed out of the 1st floor celing and 2nd floor, floor vents. No cold air came out of the 2nd floor wall vents (possibily how they installed the after market ac system?).
    Question - is there a way to install the air filter in my furnace without getting a new furnace/ac? Or without moving the ac unit under the furnace?
    The old owners must of never changed the filter/got anything serviced?
    Gas, forced air, Corsaire, Rheem, model : FGLJ-07EAUER (2000)
    I'm unable to post images/links as a new member. The Floor, the heating, the blower motor, the filter?, the ac thing that looks like a V, vents to the cieling with several ducts.
    https://ibb.co/fzOKzU
    https://ibb.co/c9nCKU
    https://ibb.co/h7hCKU
    https://ibb.co/ixwYR9
    https://ibb.co/j9h7m9
    https://ibb.co/nKNweU
    Oct 2018
    It's kind of hard to explain with out the photos
    I need 6 more posts before I can add images
    Need 5 more posts
    almost there
    two more
    last one
    last one?
    Feb 2015
    Ohio
    You have a down flow furnace and the ac coil should have been installed below the furnace. Where was the filter located? You are going to have to have something corrected and at 18 years old it may be advantageous to change the furnace. There can also be damage to the furnace caused by the coil in that location.
    "If common sense was so common, everyone would have it."
    Do it once, do it right.
    It will take as long as it takes, which will be not as long if you let me do my job.
    Oct 2018
    Thank you for confirming. They said the filter was on the bottom, I'm not sure where it would have fit.
    Feb 2015
    Ohio
    The only place I could see the filter might have been was between the coil and the blower, definitely not a good place.
    Athens, Ohio
    Evidently your home inspector failed, big time.
    Here is the proper order of components in the air flow stream, in your case, top to bottom - air filter, furnace, A-coil.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
    Cincinnati, Oh
    Hate to say it, but a worst case senario would be abuse the heck out of it, and when it gets to bad replace it.
    Oct 2018
    The filter was on the very bottom near the actual floor, so not in either of the open doors pictured.
    Nov 2011
    St. Louis
    Put a new filter back where it was and let 'er rip. It's not the way it's normally done, and for good reason; but nobody's going to die and nothing is going to burn. It worked this way all this time, right?
    When it's time to replace it, do it correctly.
    Next.
    Is the Religious Right to blame for Christianity's decline?
    They argued that, as the Religious Right became increasingly visible and militant, it became associated with Christianity itself. And if being a Christian meant being associated with the likes of Jerry Falwell, many people—especially political moderates and liberals—decided to simply stop identifying as Christians altogether.
    http://www.theamericanconservative.c...nitys-decline/
    Apr 2003
    Maple Grove, MN
    The filter being at the floor isn't really accomplishing anything.
    In order to keep the a-coil and inside parts of the furnace clean (which is really the main job of the air filter) it should be located before everything. In your case it is located after everything.
    I'd be willing to bet that your a-coil is filthy (from the top side that you can't see) and impeding airflow, unless you have return air filter-grills that you haven't noticed yet.
    I'd like to say that the a-coil should be checked and cleaned if necessary and a filter installed above it somehow, however as taylor2 said, it's probably not worth it at this point with how old the thing is.
    Good luck.
    If at First You Don't Succeed, Skydiving Is Not for You.
