Results 14 to 20 of 20
    Oct 2008
    Winnipeg, Manitoba, Canada
    Originally you said you charged out based on head pressure. It's there i sure glass?
    And as was pointed out, maybe trimming weighing in the charge.
    Sent from my LG-H831 using Tapatalk
    May 2005
    Its only 26 ounces, I can try a new charge.
    Let's give nukes a chance.
    Mar 2001
    Quote Originally Posted by primmers View Post
    I figured it was low on 404a, so I added enough to get the head psi to 250 psi..Its eatable but wont stay in the cone when turned upside down..low side is 20+..everything is set to the coldest settings..
    Any thoughts?
    suction pressure is a little high, drop it down to 16
    May 2005
    Well, what does the psi valve on the side do?? Cause the tag on it says to run it at 26 psi, and that’s where its at..
    Sep 2016
    Saint Johnsville NY
    Hopper could be
    Mar 2001
    Well, what does the psi valve on the side do?? Cause the tag on it says to run it at 26 psi, and thats where its at..
    if you never worked on a taylor it's easy to make things worse
    May 2005
    I don’t like working on them...all Ive done with this one is add enough Freon to get the head psi up to 250. I put a gauge on the valve on the side to check the psi and that’s it..some one has done some brazing where the line set goes into the hopper
