Results 1 to 13 of 13
Thread: It Gots So Hot!
    Jul 2010
    North Carolina
    It Gots So Hot!
    "So you didn't hear anything? Like anything at all?"
    "No, No. I just greased it the other day."
    2 Inch Shaft
    "Where there is a will there is a way."
    Jun 2014
    Dover, DE
    I had one once, the wheel hit the housing and blew the wheel apart. Bits of wheel actually came out of the duct diffusers.
    Maintenance guy said he didn’t hear a thing, but he changed the belt to try and get the unit running again........
    “I haven’t failed. I’ve just found 10,000 ways that won’t work.” - Thomas Edison
    “It’s not whether you get knocked down, it’s whether you get up.” - Vince Lombardi
    "In this house we obey the laws of thermodynamics" - Homer Simpson
    Aug 2015
    Buffalo,NY
    Just greased it did ya.
    SE Michigan
    Probably never been greased.
  5. Likes Metalman0880 liked this post
  6. #5
    Jan 2010
    I've seen the shaft wore down to a toothpick.
  7. #6
    Mar 2016
    Dayton Oh
    I have seen that as well. Never this though. That’s pretty awesome
  8. #7
    Jan 2013
    Central Arkansas
    Man that high you sure you have to replace the bearing, how about just squirting in some heaver grease
  9. #8
    Apr 2003
    St. Louis
    Whatttt! I can't hear youuuu! and nobody heard anything
  10. #9
    May 2014
    Bay Area California
    Posted a couple of similar shots on this site before.
    Surprising how often it happens.
  11. #10
    Jan 2010
    Central Texas
    Like a hot knife thru butter.
    I had a 150ton AHU that they just kept installing smaller belts as the blower shaft cut thru the opposite side. They couldn't figure out why the belts kept getting loose every other day. I found a 6" long gash in the side of the AHU.
  12. #11
    Jan 2001
    Ive been in industrial plants where shafts have ate thru bearings and hubs...... get there and find a mess like that...... and nobody was aware of it....
    The bible is my constitution and the constitution is my bible.
    WE THE PEOPLE refers to THEM and not YOU.
    Chewbacca Mom 2016
  13. #12
    I had one that was enclosed with external grease nipples.
    It had been greased, and the grease type and pumps-each-time, were all faithfully detailed in a Log Book. For Years.
    The failure was similar to the one pictured here. I screamed and the maintenance head showed me the log.
    I called BS but when I got it all apart I found the big piles of grease where the tubes had been left off the bearings. <g>
    PHM
    Quote Originally Posted by coolwhip View Post
    PHM
  14. #13
    Dec 2010
    Quote Originally Posted by JakRabbit View Post
    2 Inch Shaft
    Okay.........I can't take it anymore, my stomach hurts. This might be the best quote! That was my first question when I saw the picture! Thank you.
