+ Reply to Thread
Results 1 to 20 of 20
Thread: Leaking service T at Receiver discharge valve
    May 2018
    Hey Guys
    i'm working on a large walk-in freezer condensing unit with a copeland 9rb model semi hermetic compressor.
    i found a leak where a service port T was cross threaded onto the receiver discharge service valve.
    1. I was told the only way to repair would be to recover the full charge then repair the leak. is this true? or can i pump the system down by closing suction valve then at low pressure cut out close the discharge valve?
    2. the oil in the sight glass looks frothy and low (1/8" above bottom of sight glass while running). i'll get the net oil pressure later today to confirm. i was thinking of changing it while i had the system down repairing the leak. what service ports on the compressor do i evacuate after completing an oil change and/or replacing gaskets?
    Southold, NY
    Why 2 access T’s?
    The T with the arrow is always open th the receiver.
    Order a new valve
    Recover the charge and replace.
    Dec 2014
    Doesn't that one have a Schrader in it?
    Sent from my SM-G930V using Tapatalk
    Dec 2014
    Why 2 access T’s?
    Order a new valve
    Oct 2012
    Wisconsin
    Quote Originally Posted by icy78 View Post
    Most likely not. On those kinds of valve the center port is always open to the system and typically won’t have a shrader core. You just need to keep a good cap on it really tight.
    Oct 2012
    Wisconsin
    Quote Originally Posted by kalan850 View Post
    Hey Guys
    The method you describe to pump it down won’t do anything to pump out the receiver.
    To replace that valve you’re going to have to recover the charge.
    Jun 2011
    NE Ohio
    are you sure it is cross threaded or is just the flare damaged ? could be cross threaded but that is a lot of cross threading to be cross threaded
    Dec 2014
    Quote Originally Posted by Mike19 View Post
    You're probably right. I know a few times on compressor mounted suction service valves, theres been a schrader in one. But maybe thats a different type?
    Jan 2010
    They typically don't have a Schrader because there's usually a permit gauge connected to it..It's actually the best way to mount such gauge because the valve can be backseated and not have to be mid seated. Mid seated relies on the packing to hold back the charge.
  10. Likes icy78 liked this post.
  11. #10
    A Noisy Compressor Room
    And here I was told a while back that the only way a service port would not leak is if it has a non leaking core. The cap is just a dust cap I was told and you can't trust it not to leak without a good schrader core.
  12. #11
    Jan 2010
    Quote Originally Posted by Chuck View Post
    I use those brass hex caps with the built-in copper washer for that.
  13. #12
    Jul 2000
    Guayaquil, EC
    I've never seen a Shraeder valve on any service valve port...that I can recall.
    Generally, as a UL requirement, the condensing unit OEM will usually provide access ports for safety controls, like the HPC, on the discharge line or receiver without a Shrader as well...as long as there is no discharge service valve the compressor. Compressors with discharge service valves will have the HPC connected to the center port. Ports intended for operational controls will "usually" have Shraeders.
  14. #13
    Jan 2010
    This one the core is not even a option.
  15. #14
    Jul 2000
    Guayaquil, EC
    In the past, "real" refrigeration condensing units always had traditional style service valve for everything. I suspect it won't be much longer before they disappear altogether.
  16. #15
    Quote Originally Posted by icemeister View Post
    Worked on a hoshizaki self contained reach in cooler the other day. Not only did it have service ports, they were real service valves! It was less than 2 years old.
  17. #16
    Jan 2010
    Yeah I miss being able to tighten the stem packing nut.
  18. #17
    Jul 2000
    Guayaquil, EC
    I miss the solid brass valves that were not only serviceable, but they didn't rust and lasted forever.
  19. #18
    Jan 2010
    China wouldn't think of using brass ...,
  20. #19
    Mar 2013
    Treasure coast, FL
    Tell me about it.
    We installed a new Copeland condensing unit about 2 years ago and the suction service valve already rusted to the point of leaking at the pipe connection.
    Sent from my Moto Z (2) using Tapatalk
  21. #20
    Oct 2012
    Wisconsin
    I never told you that.
    The whole dust cap thing is nonsense.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
