Results 14 to 15 of 15
    Aug 2015
    YORK PA
    Seeing 0 volts from the sensor is not good. should be at something. But with out that it should not be logging points. once you get an accurate stall sensor, do not reset the map until you can rerun a point.
    I think some are getting confused with the stall sensor and the logging of surges. The sensor used to log surges is not the same sensor used as the stall sensor.
    Technically speaking, they are all heat pumps.
  3. Likes BennyD liked this post
