Results 1 to 13 of 36
    Sep 2018
    HVAC PRO download isue
    A JCI tech try to download the HVAC PRO program on my laptop today but had no luck. It is 32bit OS but the error that was coming on the screen said " due to a system error setup cannot show the dialog box!" any help is appreciated PS CCT loaded up fine.
    Connecticut
    What operating system are you running?
    Mar 2009
    Several Miles from Sane
    What OS are you running ?
    Win7 will usually run HVAC-Pro but may require adjustments to the compatibility (use XP-Pro SP2 or 3).
    As far as I know Win-10 will not run HVAC-Pro at all.
    If sense were so common everyone would have it !
    Stupid should Hurt !
    If people took care of their cars like they do their HVAC Systems you'd see a lot more people walking
    Mar 2018
    Quote Originally Posted by Cagey57 View Post
    I got it working on my windows 10 32bit with no troubles, maybe had to use a compatibility mode.. The trouble was finding a pc to change to 32 bit from 64, ended up being my personal.
    Sep 2018
    Its a 32bit os windows 7 pro dell lattitude
    Apr 2014
    You are having trouble installing the application, or downloading a controller? I’m assuming the issue is with installing, but your use of the word “download” is confusing.
    Make sure user account control is disabled (slider all the way down), and make sure you are running the setup executable as administrator.
    Sep 2018
    Quote Originally Posted by JCIman View Post
    The jci tech had an issue installing HVAC Pro or M Tool on to my 32-bit laptop the laptop screen kept saying due to a system error cannot start the dialog box
    Apr 2014
    Make sure user account control is off, and you are running the setup executable as administrator. Also, make sure he is installing from the ctools located in the sct folder of his BPP.
    What version of Metasys? Just wondering for so I know what DVD’s you have.
    Sep 2018
    I am not a hundred percent sure I will find out and get back to you I do know that he try to install it from a portable hard drive and then he also tried the DVDs and had no luck but I will find out for you and get back to you
    Apr 2014
    Make sure he is installing The latest version and has the 8.08b patch
    Apr 2014
    Get a screen shot of the error too
    Sep 2018
    I have a screenshot can i send it to your email ?
    Apr 2014
    Can you just post it here in case someone else wants to weigh in?
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
