Results 1 to 4 of 4
    Jan 2010
    Scottsboro, Al
    Horizontal ground loop question
    Say a trench was dug to about 8 feet or so and has rock in the bottom of trench. Does the rock help or hurt the transfer of heat once everything is back Filled?
    Dec 2016
    Should have a bed of filler. Rock holds heat. This should be fine.
    Sent from my SM-G930P using Tapatalk
    Jun 2012
    Northern NV
    Rock is more conductive than sand..
    Just ensure that the backfill does not press tube into a sharp rock and ruin your day.
    Athens, Ohio
    Juan is correct that the rock has better retention properties than sand.
    Check the safety regulations on working in an 8' trench. As I understand it, the requirement is that walls must be reinforced on anything deeper than 5'. It's a hassle but being fined by OSHA is a bigger hassle. And getting buried in a trench can ruin your day.
    There's nothing wrong with horizontal loops but vertical loops have a far greater average depth which yields more capacity.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
