+ Reply to Thread
Page 3 of 3 FirstFirst 123
Results 41 to 57 of 57
Thread: New, defective txv?
  1. #41
    Southold, NY
    No way is a 4000 btu'h valve gonna work on a 8000 btu'h evaporator.
    If the box ever gets down neat temp it might work. Remember the OP said low SH at the outlet that tells me overfeeding!
  2. #42
    Jan 2010
    True, if maintaining at near temperature. The correct size valve would be slightly open. That valve would be wide open. I can't see the box being able to pull down unless it's outside in a cold ambient. Or the door is locked and no one ever goes in.
  3. #43
    Olean, NY
    Quote Originally Posted by Rx7man View Post
    Just going by what I was told.. I'll certainly take his advice with a grain of salt from here on in
    I wouldn't go that far. He knows the rules enough to know how to break them for himself. Unfortunately I know how guys that get caviler about these things.
    He is probably a wealth of knowledge in many ways.
    Guinness for strength
  4. #44
    Sep 2018
    Quote Originally Posted by B_roche View Post
    I've known him for 18 years or so.. he definitely is a wealth of knowledge, and is the fellow that taught me the basics of rotary engines way back when.. He just retired last year at 72, has a shop FULL of stuff
    Had a little problem with the thermostat today, temp was -2C (28F).. tapped the thermostat and it kicked out.. put some oil on the mechanism and worked it a little, going to keep a close eye on it now
    While I'm here, Where is a good place (in Canada if possible) to get rebuild kits for the Copeland semi-hermetic compressors?.. I bojanged this one so it would work, but at some point in the future it'll need a proper rebuild.. As you can see the compressor has had some hours on it, and it wasn't running too well with that valve. To get me by I made a pair of new ones out of feeler gauges, they're working well now but when I get a chance I'd like to do it right.
  5. #45
    Olean, NY
    You can get valve plate kits from any Copeland distributer.
  6. #46
    Virginia
    Ebay has a lot of stuff …. if not there the interweb certainly does
    Google the model number and "valve plate kit "
  7. #47
    Sep 2018
    It's a KAG model.. I've found several distributors but they all want you to log in to get a price on things. grrrr
    CMP seems to be good at a glance, at least they have things in stock
    What's an estimated price for a rod, wrist pin, complete gaskets and a set of reed valves?
    I found a very nice look KAT model in 120V on Ebay for a good price, shame the shipping is a killer
  8. #48
    Jan 2010
    You buy the valve plate I don't think they sell the reeds separate.
  9. #49
    Sep 2018
    I saw the reeds listed individually
  10. #50
    Jan 2010
    I didn't look if so make sure the plate isn't wore down.
  11. #51
    Southold, NY
    Just order a valve plate.
  12. #52
    Jan 2010
  13. #53
    Olean, NY
    Or just fashion a valve plate out of an old I-beam and use several layers of green construction paper as gasket material.
  14. #54
    Apr 2005
    Australia : Queensland
    Could be that it has been rolling around in his van receiving knocks & bumps.
    The primary function of the design engineer is to make things difficult for the fabricator and impossible for the serviceman.
  15. #55
    Sep 2018
    I didn't see any marks on it whatsoever
  16. #56
    Virginia
    Im all about riggin stuff up to getter goin , but there are places you just need to buy the right stuff and be done with it...
  17. #57
    Sep 2018
    So in the spirit of doing it right next time, I bought this unit, brand new Copeland KAT compressor for $275.. I think I'll be up over that number by the time I do a rebuild and still have an old unit
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
