Results 1 to 8 of 8
Thread: RTHB compressor
    Nj Pa De
    RTHB compressor
    Anyone have any experience and literature on rebuilding compressor/ slide valve on RTHB. Thanks
    cant make this crap up
    Indiana
    They did not put out a lot of literature for RTHB, try RTHA-SB-15
    Winnipeg,MB,Canada
    What’s going on, what’s the concern?
    Nj Pa De
    Anyone willing to share RTHA - SB- 15 ?
    Need to quote a slide valve repair. Thanks for looking.
    Indiana
    You have mail!
    Nj Pa De
    Thanks always Looking....
    Anyone have experience on slide valve rebuild ? Doesn’t look fun .
    Have done many Carrier, Dunham bush, York’s but these look like once you get by the big pieces not to bad.
    Indiana
    They're actually pretty easy. Just follow the service bulletin. The secret is getting the right parts, I believe you can order the piston with the seals already installed. I have always done it the other way where you order separately and have to put the seal over the poston which is very hard to do! I later found out you can order it as one piece.
    Nj Pa De
    Thanks Always. Is it possible to just pull one end to do piston and seal ? What did you use for the puller ?
